I was on a budget so I got a tubing bender from Harbor Freight, pipe cutter and a 45 degree flaring tool at Sears. This is my first time doing all this stuff so it doesnt look the greatest, But I'm happy to say Iv'e got no leaks! even with cheap tools!
I'm planning on running the Modern Motorsports rear brake setup, and from the info I got here the F/R bias with the AZC front is almost perfect, being just a little front biased. I installed an adjustable prop. valve just in case the setup is rear biased, or if I plan to make some rear brake changes. With the Adj. prop valve installed, will it decrease rear pressure even if the knob is turned all the way down?
Iv'e got to give credit to BJ for giving me the idea to route the line FR line on the cross menber. Thanks BJ!
Help
View Garage
