makaofox
makaofox last won the day on July 10 2020
makaofox had the most liked content!
Location
New Jeresy
Recent Profile Visitors
makaofox's Achievements
Forums arent what they used to be but what the heck UPDATE I replaced the motor once the ring lands shattered on 5 of the 6 pistons. How it still drove really proves how strong the 2j is. I got it retuned with ECU masters black with nothing changed made 410whp with less fuel and ignition timing. I swapped the CD009 because its an absolutely trash transmission. If it somehow was able to have a better shift then everything would change. I tried 4 shifters and the one where you modify the trans to get it and still was no good. Swapped over to a z32 5sp and the result made me love the car. Felt amazing, never miss shifted and the gear ratio felt really good in boost. Overall the car was pretty good for 2023. SAD UPDATE as of 2025 I parted with the 2jzge-t. The car sounded amazing and had 410hp which was amazing for me BUT for 10 years it was nothing but unreliable head aches. The motor would over heat constantly, couples popping off due to blow by, transmission was terrible for majority of its time till the last year, terrible gas mileage, ignition break up and fuel cut out randomly. Basically was just screwed from the first engine builder and was dealing with those hurtles from the beginning. I said im done and want a new change of pace. Looked at several possibilities VK45/ VK56, sr20det, VQ, k24/ K20 annnnnnnd the one I landed on KA24DE. YUP KA24DE not something I was expecting also but they are pretty cheap (sort of still), can make 400hp, sound terrible (nothing compares to 2j), and should get better than 12mpg. K series is too expensive for initial rwd easily could spend 8-10k when ive spent that already on the 2j stuff over the years. So figured ka24 with 5k can get very far vs k24 3k just on trans set up alone. End of an era.
So been a long time but I finally got a retune after all these years. Only updated the fuel pump to an intank aeromotive phantom stealth and changed the boost to 14lbs. On a mainline dyno made 400hp which dyno jet numbers is 440ish on 14lbs which is exactly where I wanted to be. If i pushed it to 18 I probably can break 430 maybe 450 tops but no need at the moment. All this with 6th cylinder on 100psi while the rest are at 175/180!
Measurements for CD009 and R154 and trans tunnel
makaofox replied to seattlejester's topic in Toyota L6 Forum
All I know is the CD009 is a pretty big trans and in a 280z alot of stuff needs to be cut out. My trans is pushed up as far as it can go up and it STILL scrapes on the driveway and big bumps. Its about flush with the frame rails. Also had to cut into the change holder area about 2-3in but its still very comfortable to drive. Im using Austin Hokes shifter bracket which is amazing! My only gripe is when you cut and weld the shifter shorter, it gives you decent room but the shifter itself getting into reverse is tough. Not physically .but the downward function isnt how it is in the 350z where u have to really push it down, so getting into 6th always worries me. Not that anything will happen but it isnt as smooth as a 350z would be due to not having the same support. -
Yea 7m's are but this one was probably just bad luck from the start. Not gonna worry too much about it for now. But summer time will bring out most of the issues. The 350z trans has a pretty decent ratio, it also had the same 3.54 as the 280z/350z. So those guys usually do 4.11s but for an na thats amazing for a Holset id have to start in 4th! lol Ive needed an alignment for 7 years, im just uber lazy about it. My camber is really aggressive to fit in the wheel well. So I wouldnt be surprised if toe is out of wack. While the car was stalling and starving for fuel, I did the stupidest thing and gunned it (which brought it back to life) and BOY was it fun! The car after that did not approve but didnt die. I will check filters before swapping pumps and see if I can get another cruise out of it.
Havent been on hybrid in forever. I like the AEM cant complain, does what it needs too for the horsepower I have. Update: Still paranoid the motor will blow for a 3rd time, potentially something in the motor may be off. Fuel pump started acting up AGAIN for the 3rd pump, decided to pull the trigger and purchased a Aeromotive Phantom 340 kit. Looks like an awesome kit and a friend with a rb25 z local has one and has no issues with it. Still plenty of things to do that I havent done, due to working on my yellow z. Still need to Install coilovers Install LSD from MFactory. Debating If I wanna upgrade to 3.70 (currently 3.54 with no complaints on how it drives) Suspension alignment Fuel pump reroute and install (modify fuel cell) Brakes front may need rotors and pads Brakes rear may need rotors and pads, fix leak on caliper right side Need new tires. Currently have toyo r1r 235/40/17s and they were great but short life with my camber about 6k miles. Not surprised. Shifter boot Probably more later one, depends if the motor will hold up.
Honestly no matter WHAT swap you do it will cost around 10k-15k. 1j, 2j,sr20, vq35, rb25, rb26, ls1, lsx, and any other swap. The only cheap swap are the typical small block chevy/ ford, maybe rb20 and maybe L28ET but you can easily drop 10k into it getting to 500+hp. What adds up are things like brakes, body repair/reinforcement, rear end, fuel and interior components like gauges. I built my car in stages. First year rebuild it all suspension with poly bushings and drive it stock as I brought it. Year 2 brakes+fender flares/wheels. Year 3 collect 2j parts continue to drive car. Year 4 collect suspension bits plus rear end ie coilovers and LSD 3.90 gear. Year 5 install 2j swap. Year 6 shake down and enjoy car (blew up 2x so missed out on most of the season). Year 7 drive z and pray she makes it through the season no issues lol. Over the winter ill install the coilovers and rear end as this winter I got caught up one buying another z and gave that one some love in the hopes when my 2j is down I can still drive a z.
Very accurate post. I spent less than that going NA-T but also blew the more 2x due to bearing issue probably due to an oiling/debris issue which brought the cost back up. Alot can be done to achieve high hp and not spend a fortune thats the beauty of the 2j.
I used the stock 280z MC. It took awhile to get used the clutch. Its a fairly aggressive clutch so its a step above "on/off" but with adjustment to the rod I got it maxed out and feels decent. Comparing stock 350z MC and stock 280z MC they have the same 3/4" bore so the feel/throw should feel the same. Depending on which stage clutch you go with it will generally be a soft/low throw clutch. Unlike a stock 350z with a soft and higher throw clutch.
I used a Holset HE351cw, awesome turbo get response. Holset in general spool fast and kick in really aggressive. A/R's for holset arent measured the same apparently. But something like a HX35,40,50 or 55 are solid choices. Hx40 is a common choice for drifters. All holsets are T3's unless you have the big ones like hx55 then its a T6. So I customized my flange to T4. At 10psi im making ~330whp on a essentially a stock motor. 10psi for a holset is nothing, they can do 20-30psi all day.
Goddam the air must come in like a windtunnel thats awesome. I used a Q45 TB and for the tps I just switched the wires around. Get a flange and weld it easy as that. Q45 flange is cheap I got a really nice one on ebay for $180.
The CD009 is a great trans. It came on a car for 15 years so parts will be of no short coming. I got it at a junk yard for $600, brand new from nissan is $1800. The Getreg is 3-7k, not an option for 99% of us. Yes $3k is alot for all of us but the parts that wear out can be easily and cheaply replaced luckily. So if you burn up a flywheel just need the plates replaced with the bolts and done. Clutch isnt "custom" like they make it seem. Im not aware of which models they mix and match but im sure it can be attainable when your clutch goes. I have R200 with 354 gears im in 4th most of the time 5th brings the rpm lower but reasonable around 2k. I have yet to go into 6th at all in over 200 miles. So who knows the mileage ill get from it. I do however want to upgrade to 3.7 gears but I feel the power band would be too snappy and 1st will be completely useless even for taking off. I can already start in 2nd no bogging at all lol.
SeatleJester- I didnt want to bog him down lol. Those were the absolute necessities/ differences for the GE to be a solid platform. I personally enjoy the 350z trans its really smooth and comfortable and super easy to find at junk yards.
I went GE-T. I got the motor for $500. Far cheaper than the GTE but the distributor will limit the size turbo you want. Unless you get a manifold that brings the turbo back and lower. Front facing manifolds are easy to come by and make life easier. The wiring is different and may get pricey but its not bad with a standalone. Bigger injectors are needed regardless so i went with ID1000s. My goal was only 400-450hp which im very close too. I put down about 365 wit 10psi on a holset turbo. All you truly need to go NA-T is OEM twin turbo GTE head gasket ARP head studs for safe measure not that expensive ARP main studs for safe measure not that expensive ARP rod bolts Bigger injectors and fuel rail, I would just get a front facing manifold its easier. Standalone ECU Thats all you really need. You might need a MSD ignition box if you go for bigger power or you can do coil on plug conversion and delete the distributor but thats alot more work. Its really cheap to build a NA-T. Also consider i blew up my na-t TWICE and its still cheaper than if i went GTE lol.
Installed the pump on the first of July. Drove it around 100 miles then another bump on the road, injector drive for cylinder 1 took a dump. Had spark but injector wasnt coming on and could swap it around and the injector works but the wiring seemed to be the issue. Tested it seemed good but no power from ecu. Not the first time a driver went. Spare drivers apparently are no good. Luckily someone on ebay rebuilds them, so sending it out tomorrow. Driving it off boost its fast as hell! The welded R200 for sure wont handle it lol(I have an LSD that needs to be put together), sounds like itll blow. Car needs new tires anyway so ill let them spin. Kind of want a new fuel cell thats baffled the foam stuff will eventually clog the filter again anyways. Also the fuel gauge drives me NUTS! how can I be on E and fill up with 6 gallons on a 17 gallon tank! Looking at a classic instruments fuel link interface that has a resistor in it to really level out the fuel gauge.
Finally got the car running! Turns out my distributor wasnt sync'd in so it wasnt starting. Quick look in the manual showed me how to do that, another thing the GTE doesnt have to worry about. She turned over and did the 40min break in. My friend suggested a 2hr idle break in and in the process, 30min in the fuel pump gave out :/ So ordered another Bosch 044, this time with a check valve and a shut off valve for the fuel cell. Since I didnt think that part through and fuel will go everywhere when I swap out the pump and check the filers lol. I had the pump sitting for years in the box, so im sure it didnt help to just start using.I knew it was going out when my fuel pressure started creeping lower and lower. Had power but tap with a hammer and it kicks on. Oh well atleast the motor runs enough to do a break in! Going to aim for 500ish miles before going for a real tune and hopefully get 400hp-500hp. It made 398 at 7psi on 9 screwed up valves and a knock lol.
