Help! 280zx turbo is sick
  • Please log in to reply
49 replies to this topic
#21 Heroez
Heroez
    Always Here
  • Members
  • PipPipPipPip
  • 281 posts
  • LocationATLANTA
Posted 19 January 2012 - 05:58 AM
Thanks for the replies. I am missing a ground wire on my AFM. I was told it goes from the bolt that runs through the rubber isolator, then grounds to the mounting bracket. Has anyone ever saw this on their turbo AFM?
Posted Image
#22 r2l
r2l
    Newbie
  • Members
  • Pip
  • 19 posts
  • LocationMaiden NC
Posted 20 January 2012 - 02:40 AM
Was the shop AtlantaRacing in Decatur?
#23 Heroez
Heroez
    Always Here
  • Members
  • PipPipPipPip
  • 281 posts
  • LocationATLANTA
Posted 21 January 2012 - 03:05 PM
Yep. Have you been there?
Posted Image
#24 r2l
r2l
    Newbie
  • Members
  • Pip
  • 19 posts
  • LocationMaiden NC
Posted 21 January 2012 - 05:04 PM
Yes....I recently bought my 82 280ZX-T on Craigslist in Atlanta and he picked it up for me and did the brakes and front end for me so I could drive it back to NC. He seemed really knowledgeable and even let me look at a couple of cars he was restoring. The work he did on my car was top notch. I hate that he gave you such a flippant diagnosis.
#25 Heroez
Heroez
    Always Here
  • Members
  • PipPipPipPip
  • 281 posts
  • LocationATLANTA
Posted 21 January 2012 - 07:12 PM
Ha! You probably know what my car looks like because of a picture on the inside of that shop. The blue one with the turbo side stripe. He builds good engines, and did a nice job with installing a rear camber kit on my 260z. Put him with a problem on a eccs, and you get seat of the pants diagnosis. I guess after 30 years of working on early z cars that fuel pressure readings and resistance measurements just dont matter as much as they used to? We get along great, I just wanted a fact base diagnosis rather than intuition. I cant afford to replace everything to finally get the fix. Im sure for another grand or so he would have got it. I work full time and the wife, the house, I just dont have the time to work on it as much as I like, so I paid for time and parts in the shop. I had a different shop flat out tell me they dont like to work on turbos. Where has all the skill and give a crap gone? Hey, if you have an 82t you could help me out big time. I need to find out how the ground wire on the AFM goes. Could you take a look at the AFM and give me your best description of where the two end of that ground wire go? Or post a picture? You may have to slide the washer fluid tank up and out of the way to see it. That would be a big help.
Posted Image
#26 RB240zDET
RB240zDET
    Always Here
  • Members
  • PipPipPipPip
  • 175 posts
  • LocationAtlanta, Ga
Posted 21 January 2012 - 07:58 PM
Give me a call tomorrow I and will tell you exactly where every wire for the AFM goes. I am picking up my Turbo 82 280zx tomorrow and will be happy to help you out.
#27 r2l
r2l
    Newbie
  • Members
  • Pip
  • 19 posts
  • LocationMaiden NC
Posted 21 January 2012 - 11:49 PM
If you need pics let me know...it should be nice enough to get my car out tommorow.
was your car the one that he took to the z show....
#28 Heroez
Heroez
    Always Here
  • Members
  • PipPipPipPip
  • 281 posts
  • LocationATLANTA
Posted 22 January 2012 - 05:34 AM
No. My car left Friday day before the show. He was supposed to take his red 240z the show. Thanks for being willing to help.
Posted Image
#29 Heroez
Heroez
    Always Here
  • Members
  • PipPipPipPip
  • 281 posts
  • LocationATLANTA
Posted 22 January 2012 - 05:43 AM
Thanks man. My boss was rushing me friday, so I couldnt look up that paint code. Monday I am showing up early to get time to look it up.
Posted Image
#30 RB240zDET
RB240zDET
    Always Here
  • Members
  • PipPipPipPip
  • 175 posts
Posted 22 January 2012 - 07:19 AM
No problem. I think I found the paint code and I think I sent it to you through PM.
#31 r2l
r2l
    Newbie
  • Members
  • Pip
  • 19 posts
  • LocationMaiden NC
Posted 22 January 2012 - 01:41 PM
Are either of you guys coming up to ZdayZ?
#32 RB240zDET
RB240zDET
    Always Here
  • Members
  • PipPipPipPip
  • 175 posts
Posted 22 January 2012 - 02:05 PM
I will not be coming. Sorry.
#33 Heroez
Heroez
    Always Here
  • Members
  • PipPipPipPip
  • 281 posts
  • LocationATLANTA
Posted 24 January 2012 - 09:24 AM
Hadnt heard about it. Its a possibility. I have an update- You cant use the FSM to test the AFM. Me and a few other people ran tests just like the manual says. We tested unknown and known good turbo AFMs. They all fail test 1, and the component test. They also fail the flap movement tests. It turns out the only accurate way to test them is with power supplied. Im leaning towards saying the only way to test them is to load test them. So my AFM may not be bad afterall. The problem is somewhere else. Im about to give up.
Posted Image
#34 FricFrac
FricFrac
    Member
  • Members
  • PipPipPipPipPip
  • 712 posts
  • LocationVictoria, BC
Posted 24 January 2012 - 11:30 AM
Have you tried rebuilding the AFM? Basically you move the wiper to an unused portion of the carbon track and you should be good for another 30 years ;)
Did you test the AFM at it's connector or through the harness?
1969 Datsun 510 2dr Z22ET, 1972 Datsun 510 2dr L28, 1972 Datsun 240Z, 1981 Datsun 280ZX, 1981 Datsun 280ZXT 3.1l stroker, 1983 Datsun 280ZX, 1983 Datsun 280ZXT, 1993 300ZX Convertible, 2009 Nissan 370Z
#35 Swervey McZCar
Swervey McZCar
    Best Username
  • Donating Members
  • PipPipPip
  • 59 posts
  • LocationMontgomery, AL
Posted 24 January 2012 - 04:49 PM
Have you tried a different ECU? I know you had yours rebuilt, but something could still be fried. I have a one that I removed in order to swap in the z31 ECU. You are welcome to it. It's known good. If it doesn't fix your problem, I'd appreciate it back though ;P
Edited by Swervey McZCar, 24 January 2012 - 04:50 PM.
#36 Heroez
Heroez
    Always Here
  • Members
  • PipPipPipPip
  • 281 posts
  • LocationATLANTA
Posted 25 January 2012 - 07:07 AM
I did move the carbon trace board a few times with no change in how the car runs. I bought a replacement used AFM which the seller swears its good because he drove with it, still no change in how the car acts. Yes, the FSM has you test the wire terminals on the ecu connector, then the part itself. The test is useless though. Even known good AFMs fail testing this way. The test result between the wire terminals and the part were identicle so the wires there seem fine.
Edited by Heroez, 26 January 2012 - 04:36 PM.
Posted Image
#37 Heroez
Heroez
    Always Here
  • Members
  • PipPipPipPip
  • 281 posts
  • LocationATLANTA
Posted 25 January 2012 - 07:09 AM
I do suspect my ECU. Nobody around here has one to use. I will PM you.
Posted Image
#38 GOTHALOSISM
GOTHALOSISM
    Member
  • Members
  • PipPipPipPipPipPip
  • 1046 posts
  • LocationLas Vegas NV
Posted 26 January 2012 - 07:43 AM
Well once you get this figured out I hope to see the car in person in September at Zcon in Phoenix!
1979 280ZX "SKITTLE" (lime green, stock color) SOLD
1976 280Z "Skittle 2.0" LT1, T5, Turbo rims, and more junk.
Posted Image
#39 Heroez
Heroez
    Always Here
  • Members
  • PipPipPipPip
  • 281 posts
  • LocationATLANTA
Posted 30 January 2012 - 03:06 PM
Still no progress. I recieved the ECU and did some research on the different turbo ECUs. The bad news is, a 1981 turbo ECU lacks the dropping resistors for the fuel injectors. In that year they used a resistor pack on the inner fender of the engine bay. In my 1983, they are built into the ECU. At this point I dont want to start changing any wiring. Im staying in focus, trying to find the faulty part. I didnt want to have the car undriveable, and that is why this lending of an ECU was a major help. So I need some opinions on what to do now. Any thoughts or advice?
Edited by Heroez, 30 January 2012 - 03:15 PM.
Posted Image
#40 Swervey McZCar
Swervey McZCar
    Best Username
  • Donating Members
  • PipPipPip
  • 59 posts
Posted 30 January 2012 - 03:34 PM
That ECU came out of an '83 turbo with low impedence injectors. I used it with no resistor pack and the 1983 harness. I wrote "1981.5" on that ECU in sharpee marker after looking the number up on Jim Wolf's website. I should have written a question mark after it because I'm not very confident in that information. Please post the part # here so we could look it up for you, but I ran that ECU on a 83 engine and harness for several years. It was installed in the 83 parts car when I got it.
Edited by Swervey McZCar, 30 January 2012 - 03:36 PM.
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
