Eibach Pro Kit fender clearance?
Judging by how many Z's I've seen with this suspension set up, I'm sure this is a dead horse by now, but I've searched and can't seem to find out a legitimate answer. Speculation can only get me so far. I'm hoping to find someone who has gone through the same issue. So here it goes.
I have a 1977 280Z with Tokico Illumina 5-ways, and Eibach Pro Kit lowering springs.  It has 225/50 R 15 tires.
After searching around and seeing many Z cars with the same suspension set up, and tire/rim combination as my car.  I have noticed that my Z seems to sit higher than others.  I measured the fender clearance and I have 2 1/4" in the front and 2 1/2" in the rear.  Judging by the majority of cars I have seen, I'm guessing it should be about an inch lower, give or take a tiny bit.  At this time my interior is pretty much completely bare other than dash and headliner.  I don't believe it will add that much weight when I get everything complete to lower it down that much.
I purchased the car from a member and he seems like a good guy.  He put everything on correctly, as far as which springs go where.  The car sits level and rides like it's on rails.  I just want a little less fender gap. I wan't to go up to 16" rims when I get the money.
Any feedback would be awesome. I tried to find a Z with the look I'm trying to get as far as stance goes.
Your car is fine.
yes it looks pretty low. If you want to get rid of the "fender gap" maybe go with a 55 sidewall
Looks good.
Thats not my car. Thats how I want mine to sit. I am not sure what wheel/tire combo he is running, but thats is the stance I amlooking for. This is my car as it sits now.
That's how my '78 sits.  I like how that white Z sits, I just expect I won't get there without coilovers.
Z-ya : What size tires and rim offset were you running?
SleeperZ : That's what I'm afraid of too. I was looking at Lowering springs from Tokico. They aren't progressive but I wasn't sure if they give any more drop. Since I have Illumina's I think they should match up pretty good.
