Complete Engine Weights Table
cyrus
I would to make a complete list of all swappable engines weights and engine + trans combs weights. I have wanted this list for a long time. I will update the list. My contribution to public well being.
Shout off, small to big with all needed accessories:
1.3 13B TT (FD) Alone
+ Five Speed
CA18DET with trans 389lb
SR20DET Complete
+ Five Speed 490lbs (source Sport Compact Car)
Datsun L6 Alone
+ Four Speed
toyota 1UZ-FE + R154 mission 486lbs
+ W58 mission 466lbs
RB25DET Alone
+ Five Speed 700 lb complete
RB26DETT Alone
+ Six Speed
L28 complete with stock manifolds, SU's, and A/C compressor + 5 spd 523lbs
7MGTE complete with turbo and A/C compressor 515 lb
w/ R154(125lbs alone) 640lb
2JZ-GTE Alone 594 lbs
+ Getrag Six Speed 746lbs
VH45 508 lbs
LS1 Alone
+ T56 Six Speed
Chevy L98 Alone 540 lbs with iron heads, 510 lbs with aluminum heads
+ 4+3 OD
Chevy LS1
459(automatic)
503(manual)
LT1/LT4
562 (automatic)
620 (manual)
LT1/LT4 Alone
562 (automatic)
620 (manual) ZF Six Speed
Chevy SB (All Iron) Alone 575 lbs
+ T56 Six Speed
Chevy SB (iron + Aluminum) 500 lbs
+ T56 Six Speed
Ford SB (All Iron) Alone 550 lbs ?
+ T56 Six Speed
Ford SB (iron + Aluminum) Alone 470 lbs?
+ T56 Six Speed
Chevy BB (All Iron) 685 lbs
+ T56 Six Speed
Chevy BB (iron + Aluminum) Alone 590 lbs
+ T56 Six Speed
Viper 8.0 L alone 716 lbs
+ T56 Six Speed
Viper 8.2 L alone 716 lbs?
+ T56 Six Speed
  • Replies 50
  • 3 weeks later...
7MGTE complete with turbo and A/C compressor + R154(125lbs alone) 640lbs
Above weighed on intercomp scales.
1JZGTE 645 lbs for the engine and trans.
Above from archive Celica list
  • 3 weeks later...
Guest tony78_280z
Fascinating info, but..
Can we get the engine wieghts without tranny, and with various other tranny types. Not just the manuals. I wonder what the weight difference is.
I can't find my specific motor listed on the linking pages. This is the closest match, even though it's an 86.
Chevy small block V8 575 (generic for '60s-'70s motors)
Also, I'm assuming these measurements don't include accesories like vacuum pump / canister and egr set up or air conditioner unless specified for any of these set ups. Does it include fuel delivery and/or exhaust manifolds?
L28 complete with stock manifolds, SU's, and A/C compressor + 5 spd 523lbs OR Chevy SB (All Iron) Alone 575 lbs + T56 Six Speed
I thought there was 125 pounds difference not a mere 52. It doesn't sound so hard to get rid of 52 pounds of extra weight.
The problem is that even the references in that list rarely list the exact trim or dress of the engine. When I put my 406 together with heads, I'll see if I can find a way to weigh it and give all the details about what exactly is there, with photos.
Adding the T56 weight (140 lbs from that list I linked to) to the 575 gives 715 lb
total, compared to the L6 and 5spd at 523 lbs. Quite a difference.
But most people go to AL heads with the SBC, as well as AL intake and wp. So 575 is a bit heavier than most SBC installs in the Z. Also note how light the Ford T5 is compared to the T56. 78 lbs vs 140 lbs. Another reason I'd go with the G-force upgraded T-5 versus the T56.
If a SBC with all aluminum parts but the block (and internals) weighs 525 lbs, and you add a 78 lb T-5, that's about 600 lbs. Not bad, and the additional weight is aft of where the L6-5spd weight is installed. There are driver weight differences greater than 75 lbs :).
756- ~10 lbs for wood and that give 746 lbs. I am struggling to make the front of the car lighter. The massive radiator and intercooler are not helping. But the 22 gallon fuel cell is helping in the back. The cars weight is 2505 lbs with 7 gallons of fuel.
