LeeMS
About LeeMS
  • Birthday 03/24/1948
LeeMS's Achievements
Newbie
10
  1. Glad you're not hurt! One good lesson learned AWAYS stand on the side of a vehicle when working on a running or possibly running engine. Also good to have a fire extinguisher and a friend standing by, Now about body work......
  2. There is no ground for the coil. Ground is provided through the dist. the block and the engine ground strap. The negative side of the coil only go to the dist.
  3. Way to go Dale! You know I've been watching your progress with interest as I'm about three months be hide you. Nice job. Can't wait to hear mine roar. Good to see us old guys still can get her done. Congratulations!! Lee
  4. your intake looks great, nice smooth bends, will necking down from the 3.5 in maf to the 3in pipe restrict air flow? why not leave the entire intake pipe at 3.5? jtr has plastic pipe pieces in the injection book. i have the black cast right angle piece from e-bay, ready to get the rest of the parts. advice? is that your fuel pressure gauge mounted on the fire wall? Lee
  5. Ford/autolite had a simular inline four venturi carburetor in the 1960s. Aways thought it too looked great. The grant unit has a bit better enginering.Lee
  6. jtr seventh edtion shows the plate with the flat top for the pass side, the angled one for the drvers side. looks like your three bolts for the orignal motor mounts are upside down on the pass side. the three through holes should line up to these orignal bolt holes, two top and one on the bottom. mine is still on the eng stand hope mine is correct,Lee
  7. Correct, FUEL is meterd by turning in the mixture screws. A blown power valve will allow fuel to enter through the enrichment circuit thus the meter screw will have little effect. With two carbs and eight idle circuits (the rears are fixed and are used to consume rear bowl fuel if you never get into the secondaries thus keeping fresh fuel in the bowl) you may not get much idke variation when turning them in or out. An infared machine would be helpful. Lee
  8. So smooth.. The cleanest detailed engine compartment in a Z I've seen. Looks like it was made for the V8. Details like the power brake booster vacuum line, the lack of wires and relays all very nice. Exterior fit and finish looks perfect! Just lets me see how far I still have to go! Thanks for the inspiration. Your old wheels look like ATS german made, one of my all time best looking wheel. Got any more plans for project?? Lee
  9. To remove the ring from the back of the pump I drilled a 1/8 in hole above the ring close to the gap deep enough to get a pick in and behind the ring. The back of the pump is spring loaded, push it down and use a pick to wedge the ring out of the grove. Remove all the pump parts, remove the little vains, reinstall all the parts back in order. I also removed the pressure valve and spring out of the lower fitting, added some oil and epoxied the holes. Lee
  10. Nealio240z, recheck all your basics, check for wide open throttle, check choke operation, secondaries on a Q-jet have a lock out and will not open until the choke is all the way open. An engine will rev on the primaries only with no load. You should be able to hear the secondaries on a Q-jet open they make big noise. With the eng NOT running hold the choke wide open, crack the throttle to let the fast idle cam drop[this should deacivate the secondary lock out] then give it wide open throttle, open the secondary air gate and look down the throttle bores, the throttle blades should be vertical on the primary and almost vertical on the secondary. Try these basic checks first. Lee
  11. An easy way to check Q-jet metering rods..with the engine not running gently stick a pocket screwdriver down the bowl vent [the tube that sticks up center of the car just behind the primary choke housing just ahead of the air cleaner stud] holding the screw driver sideways angle blade toward the front of the hole you should feel a spring action when pushing down. Movement will be about 1/4 inch. You then can do the same with the engine running. Leave the screw driver in the location and quickly rev the engine by hand, the little screw driver should jump when the rods raise out of the primary jets. The spring under the rods overides vacuum.A quick and easy way to check primary rod function. Lee
  12. Nice find Brad! Good to see another V8 Z in the Puget Sound area. Were you able to get on it? How did if feel at speed? I like the tire look filling the wheel wells. You might look into a front spoiler for the lower valance, cheaper than original steel I think and easy to install. Price sounds right, I have more than that in mine and not runing yet! Have you been able to figure what kit was used or was it all fabricated from scratch? More details.This site has all the info and help you'll need. Lee
  13. With the engine and transmission out of the doner car,95 firebird lt1 t56, time for and new clutch. The engine will have stock internals, anybody have recommendations on after market clutch systems like a Spec stage one, Zoom etc? Looks like prices range from $240 to $440. Any one had bad experiance with aftermaket units? Would there be a huge advantage with a light weight aluminum flywheel? Looking the best bag for the buck. Lee
  14. I got it for the tow bill from the impound yard after a friend totaled it and walked away. LT1 T56 only way to go is complete car with the harness and all. After I got the 95 firebird and the rust free 76 280z for $1500 I found this site, does look like I got real lucky. Going the JTR route, will be a winter project. This site has all the information you'll need. Oh yes plan on double the budget, things add up quick! Lee
  15. Engine is out! We ended up using a sawzall to take out the radiator support, and took the engine and tranny out straight through the front with the balancer. It was a pretty straightforward removal with nothing in the front to get in the way. Here is a pic of the motor
