shnikees
Everything posted by shnikees
  1. Hey Everyone, I'm looking for a decent condition n42 head preferably in Seattle WA, but would be willing to pay for shipping. Thanks Morgan shnikees at gmail dot com
  2. It is easy to wire up there are 4 connections on the coils. Here is the pin-out for the ls1 coil. http://www.megamanual.com/seq/ls1_coil_schematic.gif The two center pins connect to the haltech while the two the outside pins are engine ground and switch 12v+
  3. I have 8 ls1 coilpacks with pigtails im trying to part with if you are interested.
  4. I'm installing one right now...its not easy and requires quite a bit of splicing to make everything work but the harness is very well labeled so as long as you can figure out what goes where you should be able to figure it out.
  5. That pump wont put out enough pressure to drive your injectors...in short it wont work. You need an EFI rated fuel pump.
  6. Hello, I'm looking for a left hand (looking from the back of the car) 73 240z tail light. Looking for one in decent condition. Please let me know what you have thanks shnikees at gmail dot com
  7. Check your grounds...if you have a jumper cable jumper the ground terminal on the battery to the engine block and see if turns over.
  8. From what I understand about low-z injectors is that you HAVE to use PWM otherwise you can fry things on your board due to over current.
  9. 10 posts down from yours is this. http://forums.hybridz.org/showthread.php?t=135786
  10. shnikees
    LS1 Coils
    You are very correct not sure how I missed that...however I still dont have my MS unit completed to be able to test them...
  11. shnikees
    LS1 Coils
    Heya Paul, i have seen that the only thing is he is using his tec3 to contol the coils, I dont have my MS unit built yet to do be able to do that so I'm wondering if there is a "low tech" method of firing the coils until I can finish my MS unit. Thanks
  12. shnikees
    LS1 Coils
    Hi, I'm in the final stages of assembling my megasquirt v3 with the MS2 cpu. I have the LS1 coils and I'm going to be running wasted spark. I've seen several bits of conflicting information on wither they are 5v pull up or fire from ground. Is there an easy way to test the coils before I finish the megasquirt assembly? My dad has several scopes and I can borrow one if need be. Thanks Morgan
  13. Does anyone have a spare 240sx throttle body spacer laying around theyd like part with? Pallnet doesent make them anymore and dave@arizonazcar is out of stock. Let me know if you have one FS Thanks Morgan
