S30Turbo
Everything posted by S30Turbo
  1. Yes I will keep my L28et and upgrade it to MS and Upgrade other things before going for more displacement.
  2. I currently have the f54 in a stock l28et in my car but I do have a spare n42 block. And I had an idea of making it a L31et.
  3. What is the best block for a L31et, A f54 block or a n42?
  4. Got one . Thanks cobra. Admin please close thread
  5. Anyone have a 82-83 distributor with its connector cable and spindle ?
  6. i need a Oil Pump/Dizzy Drive Spindle for an 82-83 distributor style. thank you
  7. Anyone have a v07 crank
  8. I was putting something else . Thanks. I might think of trading my l28et for a stroker
  9. I dont see it anymore in Craigslist
  10. Zmanco you got pm'ed
  11. Zmanco you have the serial number?
  12. I'll take the 8mm rods If you have any
  13. Yea I'll go with the 9mm so I can put arp bolts. Is that correct
  14. S30Turbo
    L24 rods
    Anyone have l24 rods
  15. I'm thinking of building a stroker or my back motor does anyone have a ld28 crank for sale and cheap?
  16. heres my engine bay fresh swap i still need to clean it up a bit more. Please read> http://forums.hybridz.org/index.php/topic/98611-posting-pictures-please-read/
  17. Nice . I just bought an extra ecu from a member here . I'm thinking of putting a safety fuse on the FI relay that powers the ecu. What voltage fuse should I run ?
  18. So I checked the CAS by cranking and probing the pins in the cable and I saw signal coming off the CAS. One question when I turn the key to start the started kicks. I have the s2000 push start button installed.
  19. I have the same spark problem. It turn on when I did the first start and then I cleaned up the wires ruling them Under the fuel rail n connecting the maf n doing the intercooler pluming and no spark. I also have the HEI on mine. With my 81 l28et swap on my 75 280z.
  20. Cgaheen I will try that tomorrow morning. Voong413 all the grounds that were on the injectors side by the AFM I connected them to the intake manifold for ground. The other grounds that I connected are the one in the ignition harness to the body of the car. Did I miss any grounds anyone ?
  21. Thank you newzed that's what I was thinking that The CAS is always presummed to work in the FSM. It tells me how to adjust n replace. Hopefully I will get my car to run by next week. I will try to get pics up too
