S30Turbo
Everything posted by S30Turbo
  1. Can you end me a pic of it. It's the harness that plugs in into the drivers side body harness plug
  2. When doing my l28et swap I lost the harness to connect to the cars temp oem gauge. I need one
  3. In need of a 280zxt crank pulley asap thank you
  4. Same here low beams are too low I couldn't adjust them either
  5. Yea it is the only think is that I couldn't find 8K light bulbs the kit comes with 6K.
  6. I have the kit on my 280z I like them they are working well still after 1 year. I didn't connect the DRL.
  7. I need one too . Email me pics and prices to medina_fx@yahoo.com
  8. Yea I like it but just can't upgrade to 8k
  9. I have the MSA retro projector kit ( dapper) and the rest on the lighting including inside gauges all Led also
  10. Update - The car was running rich due to tsp problems which I fix by putting a 300zx one and also one of the magnets where put on wrong
  11. Can I get a copy to my email . Thank you. Medina_fx@yahoo.com
  12. I will try that. Thank you for the help
  13. I got the SDS from Simtect Motorsports and the guy said he sent it with a base map but its running extremely rich. I'm new at this SDS I don't know if anyone has a full map with similar set up I can have.
  14. Here is my set up: L28ET stock injectors, palnet fuel rail, non-egr manifold, MSA 2 1/2 down pipe, 2.5 exhaust, intercooler, with a 300zx T3/T4 turbocharger. Running about 8psi.
  15. I just installed sds and it's running rich anyone have a map I could use
  16. I got one too. 25 shipped
  17. For now I want my car to run . It was my daily driver it's been out for 6 months .
  18. I kinda want MS so I can upgrade to bigger injectors later on.
  19. The car is currently at the shop the guys went over diagnostics with 2 ecu's one I'd fried and the other one makes the car run but it doesn't fire the injectors correctly .
  20. So after rebuilding and installing a L28et i found out that it wont start. I have bought a new ecu and still doesnt work. so im tired of messing around with it. Does anyone have a full megasquirt system that i can plug in play into my car? Thank you
  21. Hybrid240z - I would like to hear and see a Dyno on that l31et. Do you use the 240z rods or the l28et rods. I know for a stroker builders use the ld28 crank and 240z rods with 240sx pistons.
  22. Will an L28et with the same upgrades and boost make the same power as an L31et with the same upgrades and boost. Is there pros and cons for building an L31et (besides the money) and it looks like Engine builders prefer the N42 block.
