1st Turn Off Main Disconnect 2nd Make Sure Main Disconnect Is Off And Tape It Down With Some Good Tape To Make Sure No One In The Family Turns It On Put A Tag On It.10k At 240v Should Be Roughly An 40amp Capacity This Means You Could Backfeed Through Any 240v Circuits Wich Are Properly Wire Sized.possible Choices Could Be Outdor Air Conditioner Unit Service Disconect. Dryer Receptical Etc. Your Breaker On Your Generator Will Protect Everything Downstream Of It At Whatever Its Rated For 30a 240v Or 40a 240v A Slight Problem With This Is If You Hook Up To A Circuit That Is 30a And Wire Sized Accordingly With A Generator Outputting 40a The Generator Breaker Will Not Trip Even Though You Have Exceeded The Wires Ampacity Rating.this Would Probably Be A Very Unlikley Event Because The Surge In Load Would Normally Always Be Derived In Front Of The Breaker In The Panel Wich Would Trip First Under A Load Surge Its Just A Fine Detale To Remember.one Thing To Look For Is That The Circuit You Hook Into Is Properly Wiresized 30amp Should Be #10 Gauge Copper Wire .40amp Should Be #8 Gauge Copper.a Simple Formula For Figuring What You Can Run In Your House Is Add Up The Wattage Of Your Appliances Or Devices In Your House If There Not Listed In Watts Figuire Up Your Wattage By Multiplying Voltage Of Device 120v Or 220v By Amp Rating On Device This Will Give You Watt Rating For Each Item.ive Done Industrial Controls For 20 Years And Not Saying This Info Is Perfect But These Are Some Very Good Pointers If You Do This Yourself.. Always Remember Never Turn Main On Until Generator Is Disconnected OR DEATH OR INJURY CAN HAPPEN.
