philipl
Everything posted by philipl
pm,d on tranny
pm with pricing thanks phil
I really really need a set of INNER Tie Rods for my 240z
philipl replied to dave65cobra's topic in Parts Wanted
if no ones got them here maybe rock auto? -
I have got your 9mm rods from a 73 . I have pm'd you.
Mine also had no circlip i believe i used a gearpuller to remove and pressed back on with a little of some sort of loctite retaining compound to make sure it would not move..sorry this is somewhat vauge its been a little while back.....
Ive got twelve pm me for pricing ...thanks
:mrgreen:SORRY HERES THE ITEM NUMBER Item number: 320343014327
Ive got my stub axles on ebay right now their real pretty.
Ive Got A Pretty Nice Black Turbo Hood Here In Kentucky For A 100 Bucks Paints Not Real Bad Either.sorry But I Cant Ship.
Show Off Your Engine Bay! Pics Wanted, L-series
philipl replied to philipl's topic in Nissan L6 Forum
I like the stock fan being used thats cool !!! -
hey 240hoke were you happy with your treadstone setup i was thinking of going with that if so what are the dimensions thanks... phil -
My motor rebuilding is limited to two VW 1600 cc motors but in their case you just buy new jugs/cylinders with new pistons.Bearings would have to be checked although i dont think i did MOTORS LUCKILY CAME OUT OK......
hey just curious im rebuilding an l6 gonna get all new crank bearings and piston rings.old bearings look real good no real bad wear or anything cylinder walls still have cross hatching.all cylinder walls are within spec measurerd in several locations as well as all crank journals.everything looks real good can i just get STANDARD SIZE bearings and rings what do you guys think ....do i need to plastigage the bearings or anything?thanks phil
bead blasting piston domes and combustion chamber
This is way off subject but i do know i used to use crushed WALNUT shells to run through natural gas turbines to do what the company called carbo blasting this would run through the turbine and clean the high pressure and low pressure turbine wheels therefore making the turbine run more efficently this was done will the turbines were running.These were older turbines from the 50's known as ge frame three turbines... -
Thanks guys i new there were probably a few engine gurus who had heard of or experienced this process i appreciate the responses from everyone!! -
thanks for everyones input heres a snibit of info ive found from people who have tried this process.What's wrong with beadblasting pistons? > this is data from a motorcycle forum... > Steve > '72 Commando (with freshly beadblasted pistons) Glass beading will imbed into the aluminum pistons and will score your cylinders like crazy! Regardless of how much you clean them afterwards. The best alternative is walnut shell blasting or nothing at all but solvent baths! Good Luck Mike A in NJ Date: Wed, 24 Jan 96 18:50:41 EST From: Mel Smith L. Reiter enquired about cleaning(scraping) pistons a hardwood wedge makes an ideal scraper when de-coking crowns in-situ. Won't damage the bore, easily sharpened with a rasp and material is cheap (screwdrivers and chisels are phillistine-gouges and scratches). Years ago, Continental Motors(aircraft) found that polished pistons had a higher failure rate than ones with a dull finish. The reason was of the boundary layer that insulated the piston crown from the combustion heat. A polished crown would absorb heat and melt/burn thru. I've wrapped pistons with duct tape over the ring lands & skirt surfaces and bead blasted(cleaned) the crown surface with no failures and minimum carbon build-up. Another old process that may be of interest to the trident/goldie crowd with sleeved liners is Koethurizing-a shot peen process for pistons. The piston is expanded in a jig about 3-5 thou. A nozzle sprays steel shot inside the piston in a circular pattern up inside the skirt. The piston is allowed to 'grow' a few thou against the confines if the jig (looks like a little circular clamp, adjusted for desired clearance) Saves having to rebore when a little slop or clatter is the problem. Knurling is just a cheap shortcut and warps the piston. The shot peening also stress relieves and stabilizes. -FWIW Regards, Mel Smith From: Latte' Jed Date: Wed, 24 Jan 1996 19:52:47 -0500 > Glass beading will imbed into the aluminum pistons and will score your > cylinders like crazy! Regardless of how much you clean them afterwards. > The best alternative is walnut shell blasting or nothing at all but > solvent baths! I would hope nobody would try to clean anything but the top of a piston anyway, bead blasting the skirt would be dumb. A wire wheel will clean the crown about as quick as bead blasting will with less risk. Bead blasting generally shouldn't be done to the anything on the inside of an engine. I always polish the piston crown to help avoid carbon buildup, but even I admit it's a bit over the top. From: Pete Serrino Date: Thu, 25 Jan 1996 08:04:29 -0500 Regarding glass beading pistons, Mel Smith brings up an interesting point on boundry layer effects. Former list memeber Dr. Rob Tuluie has written an excellent article on the subject which can be seen @ http://www.motorcycle.com/mo/mcrob/rt-fuel2.html. Glass beading when properly done will not remove metal but has an effect similar to shot peening. It has little effect on the overall dimension. If you glass bead the skirts it will serve the same purpose as honing the cylinder, that is it will improve oil retention. I've rebuilt about a dozen motors in the past 5 years and have never had a problem with scored cylinders due to glass. Cleaning them in hot soapy water is all that is needed. Sandblasting on the other hand will change the dimension of the piston. A short application of sand, ground glass, or silicon carbide normal to the surface will *raise* it by about .0005" or .001" across the diameter which could help to compensate for a slightly worn cylinder bore. Cheers, Pete Serrino -
This is just for fun here are mine....at the moment ha ha...... 1. LA WOMAN DOORS 2. HONKY TONK WOMEN STONES 3.WILLIE THE WIMP STEVIE RAY 4. CULT LITTLE DEVIL 5. AC DC LET THERE BE ROCK 6.BONUS SONG VAN HALEN TAKE YOUR WHISKEY HOME..................thanks this will change tommorrow!!!!!!!
yes sir -
HEY KTM WHAT KIND OF FANS DID YOU USE ALSO WHAT BRAND ARE YOUR COIL PACKS MAN THAT IS A CLEAN ENGINE BAY!!!!!!!!! EVERYONES ENGINE BAYS ARE AWESOME!!!!! -
I GUESS IM TALKIN ABOUT GLASS BEAD. IM SEEING THERE ARE A FEW PEOPLE DOING THIS ON THE INTERNET IT APPEARS THAT THE PROCESS SOMEWHAT PEINS THE TOP OF PISTON AND MAKES ITS MOLECULES MORE COMPRESSED MAKING THE ALUMINUM DENSER/STRONGER....ANYBODY OUT THERE DONE THIS SEEMS LIKE A GOOD IDEA FOR TURBOS OR HIGH COMPRESSION MOTORS ANYTHING BORDERLINE DETONATION!! -
:cheers:THERES ALOT OF CREATIVITY IN EVERYONES ENGINE SCHEME AND LAYOT HERE THIS IS AWESOME LETS KEEP THIS THREAD ROLLING.ALOT CAN BE LEARNED FROM THESE PICS THANKS:icon14::icon14: -
But By No Doubt Still Would Be In Top 5 All Time Rock Bands Ever Easily.my Two Cents.............
