Kurbycar32
Everything posted by Kurbycar32
  1. i ordered floor pans from him in i think april 2011. he was very responsive and shipped immediately
  2. Preserved as a PDF Datsun _Scarab_eBay.pdf
  3. if this dude got one into a supra i imagine it would be easier to stick into a Z.
  4. If its a stick shift it could be synchro(s). when shifting from 2nd to third put the clutch in, pull it out of gear, clutch in, clutch out, clutch in, shift. if it goes the synchro's need servicing but that would likely mean rebuilt tranny or cheaper, junk yard. If its an auto theres something broke that you cant fix and you need a real mechanic. AAMCO will give you a free estimate
  5. Blue smoke=oil. So the trick will be to find the source of the oil and fix it. If your compression shows good i would assume your rings and valves aren't leaking it in, at least under low boost anyway. Check your intake to see if theres any oil residue in it to eliminate oil coming from the turbo (assuming its oil cooled)or the pcv valve.
  6. A fusible link is a piece of wire 4 sizes smaller than the wire its protecting. So your 12 gauge wire would be protected by inserting a piece of 16 gauge wire as a fusible link. I think you see them alot in OEM setups because its cheaper than installing an in-line fuze. Personally i would agree with NewZed and install a ATO style fuze in line with the same size (12 gauge) wire.
  7. I also have an N42 head without injector cutouts. I wasnt aware there were two models, thanks
  8. CL ad says it was updated yesterday 8/14/11. still available..
