Posts posted by datman
Did you seal between the IC and the Rad? around the edges that is? is it better to fill the holes in the rad support panel to force more air through the IC/Rad
Cold air intake....yes I want the filter out of the engine bay if poss.
Thanks for the info guys, I will give it a go and see how the air temp looks. I won't be running massive boost pressures.
So where do you guys mount your Fan/fans?
It cost £130....roughly $$250 and seems like very good quality
Ok I looked inside and the cores are split, there is a divide half way between the inlet and the outlet so the air will have to pass all the way through and back. Here are the specs
The THS Type 14 Intercooler is a large sized intercooler that has the inlet and outlet situated at the same end. This makes it easier to fit to cars that may have a standard side mount intercooler. It has a core size of 600x300x76mm.
Specifications
Volume 13680cm2
Core size = 600 x 300 x 76 mm
Inlet/Outlet diameter = 76mm (approx 3")
Core construction = Plate and Bar
Length between Inlet/Outlet and opposite tank = 790mm
Distance between inlet outlet pipes = 74mm
Tested to 5 Bar
Cast aluminium end tanks
Suitable for applications up to 650bhp
I was going to use the word bulb but thought you guys called them lamps
a 12v bulb from a car brake light or indicator will do.
Yeah too true, Ever see a Jag without electrical issues? Lucas also supplied parts for planes!!!!
If you look at post #46 Z-ya explains how to do it. You need to connect a 10k resistor or similar to the gate pin and the other end of the resistor to +12 this will allow currrent to flow across the drain and source, if you place a lamp where the valve would usually be you should see it light up...if you had the MS connected and controlling it you would see the lamp change brightness depending on the voltage applied to the gate pin.
Make sure you disconnect the FET from the MS before you start connecting pullup resistors to the gate pin
You could place a 12v lamp in place of the valve for testing just to see what's going on, as Z-ya mentioned try a pullup on the gate to control the lamp
Z-ya, look at the last page of the pdf...page 8, top right image shows pin numbers 1 to 4 4 being case. I must admit they could have made it far easier by showing pin numbers on the top page.
You can mount the FET with an insulator to stop it shorting the drain output to ground. Connect pin 3 (source) to ground, pin 2 (drain) to the valve and pin 1(gate) to the output from the MS.
I've got a 0.6mm nismo gasket and it was all steel covered in rubber. Looks like you were given the wrong gasket
Thanks, bought them off ebay as Supra injectors...part number tie up as 440cc. I guess some supra's here in the UK used side feed
Ok phil I'll sort some out for you if you want some amber ones.....I would need to fit my amber ones for the MOT (Inspection)
I prefer 240z with red turn signals.....probably because all Z's here have amber ones. Also better without the side repeaters front and back
Thanks Phil, I about 3 months away from finishing...I have an identical setup to you so it should save me a lot of time.
Great stuff! About time you uploaded another video
The HE351 needs a PWM signal to control the boost, so yes it should work fine. I'm going to use a similar setup to control mny holset.
Not my design but this would work for an electronic listening/recording....you could record onto windows sound recorder
details here
http://home.netcom.com/~bsundahl/knock/listen/listen.htm#Recorder
It would be tricky to detect knock on all types of engines but not that hard for one type eg L6
Ill work on something and give you the schematics
would you guys be interested in a simple device tht you could wire to a used knock sensor taken from another car. It could give an audible or visual warning. Let me know and I'll knock something up...excuse the pun:)
Excellent, Thanks very muh for the info. I will probably use the spare N42 head I have, if I decide to use a p90 I will drop you an email.
I've read the stock NA cam can be used for a turbo, do you think that's ok?
I will be running a megasquirt, 440cc injectors, holset he351cw, 60mm TB, EDIS coilpack
intercooler mounting
in Turbo / Supercharger
Posted
Also on the IC air cooling, as my car is for road use only surely most of the time spent is a part throttle, this being the case the IC I have will probably be as good as any.
