4
Smyrna388Z last won the day on January 6 2025
Smyrna388Z had the most liked content!
Gender
Male
Location
Smyrna, TN USA
Recent Profile Visitors
Smyrna388Z's Achievements
Cool. Happy it was successful for another Z owner. Im still loving he operation of mine. No more jiggling or multiple strokes to get a turn signal.
- 21 replies
- Indicator
- turn signal
(and 2 more)
Tagged with:
The OEM GSXR mirrors work great. Visibility is awesome. No more fighting to see in small, short, cheap mirrors. Thank you Suzuki for designing a great Z-mirror.
I have a great solution for covering the open holes created by the addition of adjustable camber plates to the rear suspension. 3”, Black, rubber, pipe caps do the trick. eliminates road noise and keeps burnout smoke on the exterior of the car.
EZ POWER STEERING works great!
Smyrna388Z replied to Smyrna388Z's topic in Brakes, Wheels, Suspension and Chassis
$1500, shipped in about 4 days. They will send a link that allows you to pay with a debit/credit card. -
http://www.ezpowersteering.nl/ The electric power steering from this company works great in a 1976 280Z. Direct swap with zero modifications required. Highly recommended. D374F924-A3A4-481A-B580-46EF26E66686.MOV
Steering Rack and Pinion Bellows
Smyrna388Z posted a topic in Brakes, Wheels, Suspension and Chassis
Auto Zone Speedi-Boot! 03670 is a perfect fit on a 1976 280Z steering rack. Cut one step off of the big end and you are good to go. Use a wire tie on the big end, but keep it off of the little end. This allows inner tie-rod adjustment without twisting the boot. Allow the boot small end to cover the threads of the inner tie-rod. see images of full turn condition -
It's simply a thin piece of steel. Cut the shape and drill the holes you need for the switch and the screws. My switch is still going strong; no issues. Good luck.
- 21 replies
- Indicator
- turn signal
(and 2 more)
Tagged with:
Fabricated cowl screen for ram air hood
Smyrna388Z replied to Smyrna388Z's topic in Fabrication / Welding
Ill be there as a 'cruise in' car. Saving $35 this year. Thinking about racing Friday night before ZAttack? Music City Raceway will be open for Friday night drags. The cars will look better with some rubber on the rear quarter panels. -
The products work great to restore our 40+ year old plastic pieces. The texture coating produces a nice look while hiding some of the imperfections and missing plastic chrome coating. Sand smooth, plastic prep cleaner, plastic primer, SEM 39853 texture, then SEM 39033 color coat (charcoal metallic). Works great.
Posting to let everyone know of a very cheap option for grill screen or any opening you want to dress up or keep debris out. I used a gutter screen from Lowes to make a mini grill for the front opening in my hood. The screen is soft enough to easily shape and strong enough to be functional. It is even powder coated gloss black. Details in the attached pictures. Two pieces would make a nice grill. One above the bumper and one below. Note: The picture of the full piece is missing the piece I used for the hood.
Problem resolved! Cutting a right stub axle to be used on the left side worked great. I built a wooden jig to spin the axle under a chop saw. I used this setup to cut a cir-clip groove and to shorten the axle. Awesome results. I used two clamp collars to help guide the chop saw blade, this made for precise cuts. All I have to do now is replace the seals and install it in the car. 4.08 rear gears will be pushing my 280Z down the road. trim.11990050-DDBD-4E19-B3FF-4B71435BBC12.MOV trim.79395761-6E43-4FB2-8151-FC67A0514FF8.MOV
