As far as aftermarket parts no upgrades. haven't mess with the car much it's running pretty good.
Got it tune
265hp @14 psi
322torque.
Most of my time is going to my other build
1971 datsun 521 truck I'm swapping a 3sge beams engine.
Which turbo where you running? I think they are standard gap for a l28et.
Head is a stock p90a head other than solid lifters.
Shawn from Church Automotive who is a well know tuner in southern California said I could go higher but he wouldnt recommend it on 91pump gas.
He also said engine was running pretty good.
1971 240z with L28et, ms2,edis-6 coil on plug, intake manifold similar to the senza pari group buy one,stock t3 turbo,pallnet fuel rail.
What guys think.... Pump gas 91 octane.
So decided to go with edis-6 since my 12-1 diyautotune stock 82 turbo dizzy was having sync problems. Now so far is much better. Also went with coil on plug.
is this the correct way to activate EDIs on a MS2 3.0 board The red is what needs to be done correct? On the wiring guide it says to
jumper tach select to XG1(but theres all ready jumpered tachselect to vrin) do i add another wire from tach select to xg1
Jumper opto out to tsel
But to wire the vr sensor it says to tachselect to vrin(which it is already) wire TSEL to VROUTINV on the other section of the guide it says to wire it to opto out
