Long story short.. I've been lurking here for quite a long time. I recently bought a '79 280ZX automatic that I am going to fix up as a new daily driver.
The car is clean, and only needs a new paintjob and some interior re-upholstery. However, the engine bay was a mess when I got it. Wires spliced everywhere, vacuum hoses ripped, everything dry-rotted or broken. The car had an overheating problem, and the seller thought it was a cracked head so the car came with a brand new rebuilt head that I am going to put on it. The funny thing, though, is that when I took the clutch fan off it had no resistance to turn.
Instead of trying to fix everything, I want to start clean. I don't want to go standalone, though, because this is just going to be a daily driver and I want to retain a/c and cruise. I am going to get the engine harness, ECU, and fuel rail from a 4.0 jeep and take the nissan engine harness out. The good thing aobut the Jeep ECU and engine harness is that they come in the engine bay in the jeeps, so I can put this one in my engine bay and not have to worry about crawling under the dash. The Jeep fuel rail has the same injector spacing as the L28 fuel rail, and I can tap a return line in the rail and make brackets so as to use on the L28 return fuel system. There is a jeep 4.0 cherokee parts car here at work, so I can just go and rip all the stuff I need off of it.
I will be able to run speed density to free up alot of room/headache, and I will also be able to easily find the right size injectors I need.
So, onto my questions.
-Will the stock cruise control work without the stock ECU and stock engine wiring harness? Is the engine wiring harness even separate from the body harness?
-Is there a distributor that uses mechanical advance VS. the stock L28 vacuum advance that will fit onto the L28? I'd like to use the jeep ECU to control the timing advance, but there isn't any way I can use the jeep dizzy on the L28.
