Everything posted by dat240zg
As the title states, one of the last jobs that I have on the Z is the wipers. I've searched and read and then searched some more. I'm using a 21 circuit Painless wiring harness, but am getting no where with the wipers. I'm also doing the Honda wiper upgrade at the same time, and have it wired through a relay as instructed in the honda wiper upgrade thread. I'm not sure if I'm not understanding the Datsun wiring correctly or what, but I've wired it based on what others have done and I'm just popping fuses and not getting anything. Here's what searching has turned up: (there are conflicts between the different posts about which wire is which) Blue/White & Blue/Red = Windshield washer Yellow/Green = Wiper power feed Red/Blue = High Speed Yellow/Black = Low Speed Blue/Yellow = Intermittent Black = Ground The Painless Harness has only one wiper feed wire (#905 - Blue). I have the Painless feed wired to Yellow/Green. As soon as I turn it on, I blow the fuse. Would someone set me straight on this? Do I have it wired wrong? Thanks for your help, Bryan Dat240zg
Quick question: Which wire is the power feed for 280Z wipers?
dat240zg replied to dat240zg's topic in Ignition and Electrical
Searched more, found it. Mods, please slap me in the head. -
Oscar: I replied to your PM. Hopefully, we can come to an agreement. Bryan
So, just to make sure I understand correctly, before you clear things up one last time, you're going to refund my money, correct? When you admit that you have serious product issues, doesn't it seem right that you'd refund the money that you took from a customer when you knew beforehand that your product was crap? Again, you ask for help and understanding, but then don't fix the problem that you admitedly created? Come on. Quit hosing people. If you can't make a decent product (as evidenced by the problems that have been posted), then do the Z community a favor and get out of business. Or make it right. Either would be fine. Bryan Dat240zg
Did you read my pm regarding a replacement piece or refund of some type? You had asked for my help on how you could make it better (which I gave) but have made no effort to fix my situation. It seems like others that have posted their issues have been able to get help - and it would go a long way towards making people on the board feel good about ordering from you again. Bryan
Looking for suggestions here. Current exhaust system is (from motor back): Sanderson headers, stainless 2.5" mandrel bend pipe to a y-pipe joining behind tranny, moving to stainless 3" pipe to a summit bullet style silencer and out to a magnaflow muffler. Motor a healthy LT-1 and the Z is fully dynomatted. From the outside, it sounds really nice - deep and smooth. From the inside, well, it makes your ears bleed. Not really, but close. I seriously have to wear ear plugs. Forget listening to music or talking. I'd like peoples opinions on different muffler options that will lower the noise level to I-can-drive-it-without-resorting-to-sign-language-levels. Thoughts?
I can appreciate the glass half full outlook. Truth be told, there wasn't much left by the time I cut away all of the material, but, it is what it is. Bryan
I hate to be a downer, but I purchased the corvette tail light panel from them on ebay and it came cracked and mis-shaped. The crack was from shipping, but it wouldn't have mattered anyway as the panel was bowed out in a such a way that it would not have fit the car regardless. $165 down the drain. I was under a time crunch to get the Z ready for a show, and as a result, didn't take the time to contact the seller and tell him about it, I just tried to make the best out of a not great situation. I ended up cutting the (cracked) panel using the outside parts to make camaro tail light panels. I may have had the lone bad experience, but just be aware!
'71 Camaro Tail lights & tail light panel redo - pics inside!
dat240zg replied to dat240zg's topic in Body Kits & Paint
Here are a couple shots of the lights done: The car is real dirty, so when it's back on its wheels I'll wash, wax and get some better pics. Two spray can coats of metallic black, wet sanded between each followed by two coats of clear also wet sanded between each. Finished off with some buffing and the gloss is crazy - from a spray can! Pretty chuffed with the way that they truned out. All thats left is to mount the lights and to come up with a solution for the backup lights. -
What are you doing for backup lights? -
That's it! Nicely done on the rear panel! I think I'll be doing that next year. -
You're right about being installed opposite of the original position. Not really noticable unless you're actually lower than the lights. Here's what I've learned so far: 1. The lights are too deep (with the plastic back). Fortunately, I had a set of '71 Corvette tail lights that I was thinking about using and they have a very slim back, so I've married the two and it fits fine. 2. Biggest thing, and what I'll probably do next summer, is to go find a wrecked '71, and cut the metal around the tail lights and then weld it to the Datsun tail light surround panel - as opposed to going the fiberglass route. I would have done that any way, but bought the corvette tail panel from the vendor (big mistake) and didn't want to waste more money. 3. The Camaro tails look big!... until you get them up there and then they're actually a little undersized. I may go to one of the classic junk yards in the area with a tape measure and see what other lights are out there. I should have pics of the finished product tomorrow. I sprayed my last coat of clear tonight. If you have other questions, just shoot. Bryan -
Well, before I swapped colors, I wet sanded the metallic grey/black and it looked real nice. Now to finish the other side. New pics to come. -
Well, they're getting close. I sprayed some color on them, but don't really care for it. I think that I'll sand it down and go with a simple gloss black. What do you all think? -
Actually, I was just testing which way I'm going to have them. The solid red will be on the outside. Should turn out well. More pics to come. -
Well, I was stuck waiting for all of my parts to come in to finish my R230 swap and started thinking about tail lights. I've always liked the skyline tail lights: The cost though is crazy...$1200 for a set of lights and the surround panels not including shipping!!! So, I started looking on ebay for round tail lights and purchased a corvette style tail light panel. I purchased a set of early seventies Vette and Camaro tails and settled on the Camaro lights. The corvette tail light panel came from a vendor (Custom Z Parts), via ebay, and got to me cracked and misshaped. Rather than screw with the vendor, I cut the tail light panels down, and was able to get a second set of tail light panels from a good friend. I trimmed the panel down, mounted the lights and here is the early version of what I have: The panel is just screwed in place, but will be bonded using 3M panel bond adhesive and then the edges fethered in with body filler. End result should be pretty cool. We'll see!
How much are you looking to spend? I have a set that are on my 240.
Saw those. Just didn't want to get into a bidding war with someone and end up paying out the wazoo for them. Thanks. Bryan Dat240zg
Needing the pair. Thanks for your help. Please include shipping to 72758. Have a great one!
Looking for a set of billet R230 CV adapters. Bryan Dat240zg
I've searched and can't find the answer, so I'm hoping someone else has already experienced this. I'm getting ready to pull the trigger on a 2010 Infiniti G37 R-230 rear end. Any one know a reason why the newer R-230's won't work in the swap (different bolt patterns, spacing, mounting, etc)? Bryan Dat240zg
Finally in a position to get the R230 swap going, so... I'm hoping to find someone who may be abandoning an R230 swap. I'm needing the entire mounting kit, diff, axles, etc. Anyone have wanting to get rid of theirs? Bryan Dat240zg
How to redo your LT1 wiring harness.
dat240zg replied to dat240zg's topic in Gen I & II Chevy V8 Tech Board
"Is this for the MAF of speed density systems?" I may be wrong, but I think he meant to type MAF or Speed density. -
Let me know if I can help you with info. Bryan
