G-Tech
    4
Posts posted by G-Tech
  1. i love hearing about all the different solutions s130 owners come up with for different obstacles. Like a dodge omni steering rack!?
    Mine is doing great, so i dont even want to ask how the apex front crossmember is or how you did the s13 rear sub and etc, etc...i am trying to leave mine alone right now.
    Cant wait to see some pics though. here is a couple from mine this year.
    Anyone else want to check in!?
  2. i too have the MSA kit but i have the front bumper with fog lights. the side skirts are a pain to hold close to the fender. i fiberglassed a 6mm stud to the back side and drilled a hole in the fender for it. you are able to reach in thru the wheel well to put a nut on it. Skillard.com just came out with a different body kit for it that is nice looking. and there is no great option for widebody kits other than some old 80's design's. there are some wheel flare options though As stated before STAY AWAY from Showcars.com, i had a horrible experience with them.
    PS: 280zx is different car than 240z,260z, and 280z. you will not find a kit that makes the front end look like the older Z's
  3. IM NOT A BIG SELLER OF THINGS, JUST TRYING TO MAKE ROOM ON MY STORAGE SHELF. IF MY PRICING IS A LITTLE HIGH I AM OPEN TO OFFERS.
    All Pricing DOES NOT include shipping. if your interested, send me your Zip code and i will get you the cost for shipping
    WHAT I HAVE LEFT:
    Stub axle and Companion Flanges are $150 for the set, i will sell just companion flanges for $100 for the set. Or just stub axles for $50 for the set (1 SET LEFT)
    Custom Made Companion Flanges Adapters (280zx flange with 280zxt CV-joint adapter welded too it) $50 for the set
    280zx Universal Joint Half shafts for $100 for the set
     CV-Joint pair (needs new boots) $150
  4. Before i ask, i want to point out that i did donate to the site. So i dont want to be taken as someone trying to sell stuff without following proper procedure.
    Time to get rid of some things i no longer need. Looking for an opinion on what they might be worth. i currently have a couple sets of 280zxt stub axles and companion flanges and even a set of adapter companion flanges that i made (in my machine shop), also i have a few 280zxt CV-joints that i think i need to sell individually cause somehow i ended up with 3 driver sides and 1 pass side. 1 has good rubber boots, the other 3 need rubber boots. and lastly i have a set of stock 280zx universal joint half shafts that are in good shape.
    i appreciate any help on this cause normally im a hoarder of datsun parts, not a seller but i have converted everything to a different setup so they are completely useless to me.
  5. 1st should be which ever has the better body. If they are both similar in condition you should keep the 280z. The zx has less support from companies for parts. Possibilities are endless with the s30 chassis.
    You could always get the zx running and just drive it while you get the 280z ready for the motor swap.
  6. Basically what you have are generic tractor trailer tail lights. They are nice and simple and there are lots of options for them. i would atleast find LED ones so they are bright and look a little more custom. When you do LED's the car might think that the bulb is blown cause there is little resistance with LED lights. if it does that, you may want to get a resistor to put inline so the blinker doesnt blink 100mph. They are only like $7 each and install super easy.
    i use that style light also but i kinda went crazy and made my own tail light buckets and lens to house the tail lights to give it a custom look. i found these cool versions of lights that use an infinity mirror set up to make the lights look like a tunnel when lite up. i also used the resistors and my lights blink normal.20190310_182651.thumb.jpg.351bad894e43533235b41bbbe15d9324.jpg
  7. 9 hours ago, Chopshop280zx said:
    I have a 1982 280zx with a stock 6.0 ls with a powerglide. The car works great out of the whole but I need to put more power down how can I get this rear end to handle more horse power. If I could get this car to hold about 500 horses out the whole it would be a killer. Some body help me remove these stock axles please. The Z car world has forgotten about the 280zx
    i have a 280ZX with LS swap that has 400WHP and a 6-speed. i have the stock r-200 with Quaife internals. that has held up flawlessly. there are other options for internals for the r-200 also. that diff should handle it fine.The problem you will have is if you still have universal joint half shafts and then stub axles was the week link i found. Mine beeing a stick shift though is harder on the drivetrain. you might be fine if you just upgrade to 280zxt CV joints and you will have to switch the stub axle companion flange also. (both of which i have that i would sell if you decide to go that route). if you can afford it, i got custom Chromoly stub axles and companion flanges made to switch to 300zxt CV joints (gonna be close to $2k). when im at the drag strip i dump the clutch at 4k RPM and run 11.8's all day. it takes it fine. And yes, the Z car world still does not appreciate the 280zx. There are a few of us going the extra effort to make them work however.
    And to keep this on track with this 5-lug conversation topic, shops that are making custom stub axles and custom front hubs are willing to make them 5-lug for you. i found that F-body Camaro wheel studs are almost identical so i bought ARP wheel studs for the Camaro and i run them with my 4-lug set up with no issue
  8. You kinda have the same dream as alot of zx owners. Unfortunately I've never seen it done to great success. Your car is surprisingly different than the older 240,260 and even 280z..if your very talented with body work and or have some money to pay someone talented, you can be the 1st. My suggestion is embrace the uniqueness of the 280zx (s130 chassis)...i have a 280zx also so I'm on your side...
  9. depends how well it ends up running as is. chances are you will chase down a handful of little issues. in which case you mine as well go for the swap so that you can get to know it better and make things right. it will be a little faster also. Value wise i think going for the swap is going to be better too. it doesnt look like an original turbo car so there is not big value for it the way it is. older Z's are getting good money for original but i dont know anyone that specifically searches for an original 280zx. only turbo 280zx's are worth leaving as is, the rest are free to do whatever with in my opinion. and trying to make it a turbo model will be more work than the VQ35.
    good luck with it, it does look pretty solid from a quick pic that you have
  10. i dont see why you would need to swap crossmember, the motors are the same as far as bolting to the car goes. the suspension is the same, no need to change that either. i think the hardest thing is going to be swapping the harness.
    the rearend is possibly different. turbo cars are R200's with 3:54 gears. you will have to find out based on what exact model you have to know what rearend you have. the CV joint style halfshaft in the turbo car is much better. for that you will also need the outer stub axles that mate up to it. Bottom line is i think you will want to swap the entire rear subframe, thats if your parts car has all that still.
    ive never done it, just speaking of my experience with s130 chassis so hopefully someone who has done it will confirm my beliefs
    good luck!
  11. Depends if you have the computer or not already. if you dont, you just have to get a DBC throttle body and a F-body Camaro computer. They were DBC. Thats what i did. Im just a mechanical guy so it seemed easier but i"ve learned its not a big deal to do DBW if thats what you have. Im not sure what has to happen with the gas pedal for DBW but my guess is there is a simple solution for it if you research it.
  12. i dont have the same swap as you but when i did a swap in my zx i explained to the driveshaft shop that the rear-end doesn't move and they took my fixed measurements and made it so the slip yoke goes half way in. this way when you install it, you can slid it all the way in 1st, then pull it out to mate with the rear-end. if you make the driveshaft length with the yoke fully seated, you would probably fight with it when you lift the back up to meet with the rear-end .
  13. He buys plain rotors then has them slotted by someone else. Guessing it saves him money somehow, probably buying rotors in bulk. I like his stuff, i have his full brake kit for my 280zx (although i didnt know i was losing my parking brake till i was installing everything) but he has never been good at customer service. Not sure if he is too busy or what.
  14. The bumper on top I've only seen in pictures from cars in Japan, so not sure you can get it in the states. The front end on the bottom looks like someone made the grill and lower air dam from an older z fit somehow...it actually looks like they did a good job. I dont know how easy it would be cause I've never seen that before. I would check out MSA (motorsport auto)...you can do a simple lower airdam to add a different look or I bought their full front bumber with the fog light buckets molded in. I'm pretty happy with it, definitely changed up the front end. Alot of people (me included) like the look of the older z front grill but you will find that the 280zx is very different from the 240,260, and 280z...many people have tried to make the zx front look like the older z's and I've seen only a couple good results...all depends on how much knowledge and experience you have with doing body mods
  15. I would say it's better to replace things like the exhaust with a better exhaust or replace suspension with better than OEM parts....the turbo model was the top notch option for zx's...if it was a turbo model and not already modified, then I would say it's best to keep it pure for resale value....the 280zx isnt getting alot of appreciation and unless its absolutely original, I dont see anyone paying top dollar cause its 10th aniv.
    It also cost alot to make a zx pretty fast with horsepower and all that. So you wont get your money back.
    I think someone will pay respectable money for a good running one with mild upgrades...
    That's my 2 cents anyway
  16. Very cool to hear!!! I've been seeing your post for  while now. Never really followed to close as I'm a s130 guy but to hear your driving it is awsome!!. So often there are threads of builds that go longer than expected. I've been a victim of it too. So congrats on beeing a guy that's completing one to a point you can drive it again. They are never done, so keep it up...
