Carl Beck
Everything posted by Carl Beck
Hi BJ: Doesn't the use of a 280Z rule out the testing of the BRE Front Spook? The lower front finishers on the 280Z are lower and rounded to allow more air flow into the larger radiators on the 280Z's.. and the BRE Spooks were made to fit the lower finishers on the 240-Z's... The BRE Spook was the most effective at offsetting front end lift - at least in the C & D Tests... FWIW, Carl B.
Aerodynamics DONATIONS NEEDED!!!
Carl Beck replied to Mikelly's topic in Windtunnel Test Results and Analysis
What is the PayPal Fee? thanks, Carl -
Which spoiler works best?
Carl Beck replied to 260DET's topic in Windtunnel Test Results and Analysis
Has anyone been following the Dodge Ram SRT-10? 500HP Viper engine.. 150MPH top end and sub 5.0 second 0-60mph? At any rate some interesting "aero" devices on this truck - developed via CFD Modeling/Visualization plus wind tunnel and on track testing. See: http://www.dodge.com/srt-10/ Note the size difference between the Ram SRT-10 and the Ram Daytona rear aero devices.. Then an interesting article related to Daimler/Chrysler - Dodge and aero design efforts/processes.. http://www.creativemac.com/articles/viewarticle.jsp?id=25605 FWIW, Carl B. -
Hi PrOxLaMuS© / 1_tuff-z (everyone): Hi Guys - thanks for the welcome. I've been a lurker here for a long time - ever since pparaska started harassing me and I like the way jmortensen administers/moderates.... just been too busy with a hundred other things to get involved in any of the very interesting threads. The subject of Z Car aerodynamics however sucked me in this time... If you don't have a copy of the 74 Car & Driver article, e-mail me and I'll let you read my digital back-up. It will be interesting to see how the HybridZ wind tunnel results match up... or not... Carl e-mail: beck@becksystems.com -
Hi John / OTM (everyone): It is certainly contrary to what Car & Driver found in their tests in 74. Stock: 140 lbs of Lift on front wheels @ 70mph 20 lbs of Lift on the rear wheels @70 mph BRE Front Spook canceled 105 lbs of Lift and increased gas mileage by 0.4 mpg BRE Street Spook (no brake ducts) canceled 115 lbs of Lift BRE Rear Spoiler added 75 lbs. of down force @ 70 mph and 0.2mpg C & D custom 7" rear spoiler (at 50 degrees from horizontal) Added 160 lbs of down-force to the rear but off loaded an additional 20 lbs from the front. It also hurt gas mileage by 0.6 mpg. FWIW, Carl B. -
Is this a reasonable price for floor board replacement?
Carl Beck replied to Alri's topic in Fabrication / Welding
Hi Alri: I would recommend finding someone to weld them in FIRST. If you show up at the typical body shop with no floorboards at least one of two things will most likely result. 1. The guy at the body shop will not have had the opportunity to decide for himself, where the best place to cut them out would be (so he would have access to weld). He'll also not have a good concept of how they should look when he'd done. 2. Knowing that you are now stuck with no floorboards - and MUST have them done, his price can go up.. If your going to cut them out yourself - work out a deal with the person that's going to weld them back in BEFORE you start cutting. Here is a good article on doing the job - it will at least give you some idea of how it goes.. http://zhome.com/Classic/240ZFloorboards/ChrisFloorboards.htm BTW - looking at the picture of your Z - you're just North of me.. FWIW, Carl B. Carl Beck Clearwater, FL USA http://ZHome.com -
Hi datsunlover: Just an interesting side note: That first "bump" on the "latch" when new (at least on the 72 240-Z) - had a nylon sleeve on it (kind of a horse shoe shape). Over time, they either wear out or get brittle with age - crack and fall off. At one point I attempted to find a plastics shop - that could reproduce the nylon sleeve ... but the cost of the molds needed for injection molding were just too high. In the process of attempting to remove that nylon sleeve from the one good latch I had, we managed to break the original sleeve. After that nylon bumper falls off - then the metal to metal contact between the latch and the catch start to take effect. At any rate, your solution should work fine... FWIW, Carl B.
HI Dave: Always ask yourself - "where is the energy source or force". Most of the time that will help you answer your question. Be it a wing tip or hot air - it's at the center, and therefore the highest speed winds... FWIW, Carl B. -
Hi Jon: Thanks for the welcome and the response. This is a good discussion to have, before the wind tunnel is cranked up, and indeed I could be conceptualizing all this in the wrong manor. How I understood it :(which could very well be the wrong way of thinking about it) "It" being the Kamm back design and its effects: I believe that Dr. Kamm did indeed worry about both Drag and "push". Yes, the tumbling/spinning air flow - ie. rotating in a horizontal circle, is moving at a higher speed, than the air flow coming off the car and transiting over the top of that circulation. The speed of the circulating air also gets higher as it approaches the center of circulation - and thus the center of that rotation is the lowest pressure area within that circulation. The center of a Hurricane is its lowest pressure area. But when Hurricanes come ashore - the circulating bands blow with very high wind speeds.. and thus exert very high pressures on anything they encounter (a mass of air molecules moving at very high speed). The high pressure area at the rear of the car in this case, is not the center of that circulation (low pressure area), but rather is at the point where the higher speed winds of that spinning circulation - strike/collide with (push against) the rear of the car. Just as the air striking the front of the car creates high pressure. As I understood it (that qualifier again) - Dr. Kamm wanted that center of circulation positioned at a point behind the car, to not only take advantage of its ability to effectively reduce separation turbulence (support a smoother transition of the air flow off the back of the car - much the same as extending the body itself back to a pointed end), but to also take advantage of the energy in that spinning low pressure area - and apply it to the back of the car - yes to gain a little offsetting "push". Adding the Nissan/BRE rear spoiler - effectively moves the center of circulation rearward away from the back of the car, and thus reduces or eliminates the high speed winds in the circulation from hitting the back of the car. I think "suction" is a term that describes an effect, I don't see how it can be a cause. Maybe if we're lucky we'll get a physics major upset enough to jump in here, as we mangle the subject. At any rate - If the pressure sensors are put in the right places on this project - we should be able to see more clearly just what is happening. FWIW, Carl B. -
Hi Mike kZ Thanks for the welcome. I know several of the people here and have been a lurker for several years as well. No I don't know what would happen to the air flow with a Supra Style wing added. I've never seen any tests with that type of device on a Z. On first appearance, I would venture a guess that it would have to move that high pressure area at the rear of the car, farther back and perhaps a little higher. That one would be a good "test case" for the wind tunnel. It would be especially fun to move it's mounting position up/down the slope of the rear hatch to find the best position. That being where the down-force it applies is high enough to cancel any lift at the rear wheels, without adding unwanted drag to the vehicle. Is it possible to adjust the angle of attack on that type of wing? I can't recall, without going back to look - but I believe one method of measuring increases or decreases to aerodynamic Drag on a vehicle is a "Cost Down Test". You run the car up to 70 or 80 mph, then let it coast down to about 30 mph. Then you measure the distance it took. Below 30 mph the effects of aerodynamic drag are minimal compared to the physical drag from the tires and drive line. There was at one time a wing type "airfoil" made for the 240Z, but I've not seen one actually on a car for at least 25 years, nor seen one tested by anyone. http://zhome.com/History/Images/72Broc4.jpg 240Z Airfoil Of course the Wail Tail on the 79 280ZX-R's was most effective on the track, at offsetting Lift without adding too much Drag. FWIW, Carl B. -
Hi David: As I understand it - the Kamm back design used on the First Generation Z's has the effect of forming a turbulent high pressure area at the end of the car. That high pressure area is what forces exhaust gases into the passenger cabin, when the rear of the car isn't properly sealed. When you roll your windows down, that exhaust smell gets worse. (the opposite of what you would expect) That is because the high speed airflow along the sides of the car create a low pressure area, that is, lower pressure than that in the cabin. So when you roll the windows down - while outside air is forced in and circulates with the passenger cabin - cabin air also actually gets sucked out the side windows. Somewhat the same effect as air flowing over the top of a chimney (heat alone doesn't push smoke up a 20' chimney - ie, Venturi effect). Roll the windows up, and open the Z's Fresh Air Vents in the front of the car - and the exhaust smell gets better (ever so slightly)... because the forced air induction from the front of the car is now creating a slightly higher cabin pressure, but still not higher than the area behind the car... Add a rear spoiler and the exhaust smell is greatly reduced. That is because the effect of the Kamm back's turbulent high pressure area is effectively moved farther rearward, and the exhaust gases are no longer held as tightly against the rear of the car. The pressure differential between that high pressure area behind the car and the lower pressure area within the passenger's cabin, is not as great as it was before the rear spoiler was added. FWIW, Carl B. -
Hi bjhines (everyone): I applaud your efforts and like the idea of spending a day in the wind tunnel with a 240-Z. Exactly why I like that idea, I really don't know! The truth is, I don't know exactly what physical measurements can be taken in the wind tunnel. That is to say, I don't understand what test equipment the car would be hooked up to, nor the type of data that test equipment would report. I'm hoping that you might be able to give me some specifics related to the actual test equipment hooked to the car, that would measure the physical effects of the aerodynamics being applied - as opposed to the intrinsic discussion of the aerodynamics themselves. I noticed that Cygnus - suggested "measuring" lift/down-force at speed. Is that something that is actually measured in a wind tunnel? For the tests conducted by Car & Driver in 73 as I recall - they hooked a car up to a device that measured body deflection from standard ground clearance as the car was driven at speed - and then computed the amount of lift or down force being applied to the front or rear of the car. Is a physical device like that used in a wind tunnel? He also suggested plotting drag, which would imply that it to was being measured, as well as identifying pressure points at key locations vs speed. Is there now some test equipment that actually measures the drag created by an object in a wind tunnel? (I was under the impression that drag was calculated from either frontal area or total surface area) Do they have 3D scanners in the wind tunnels now to provide that data? Or perhaps in a stagging area ahead of the wind tunnel? In your reply above - you seem to indicate that data related to airflow is really all that is "measured" (for lack of a better term on my part)... and perhaps high or low relative pressure points could be measured... Any help you can provide in understanding exactly or specifically what is going to be measured or what is not actually measured, but rather computed or estimated in this project would be greatly appreciated by me. It's not so much a matter of knowing what aerodynamic devices work, as it is a matter of knowing which one's have a positive effect great enough to justify the cost of applying them. thanks, Carl Carl Beck Clearwater, FL USA http://ZHome.com -
for those that asked about my garage project
Carl Beck replied to grumpyvette's topic in Non Tech Board
Hi Grumpyvette Very nice garage indeed... A few words about Ben Person Lifts... In another life, back In 1975 I owned/operated a Muffler Shop - had a new Ben Person Pipe Bender and two 4 Post Lifts. After I actually learned something about the business... I realized that I should have bought a Huth Pipe Bender... and I found that Ben Person was a young company at that point. One day I was letting a car down, as I watched a fine young girl walk by outside... distracted to say the least... My attention was returned to the car when I heard it sliding sideways and threatening to fall off the lift!! YEA GAD !!! One of the "stops" had failed to retract on the Left Front Post...so that corner was still at its uppermost position... in the mean time the other three corners were allowed to come down... The car was sliding backward on the ramps, as the Right Side was now about four feet lower than the left front... As the car slide - the lift made a horrible noise... twisting posts, drive on ramps sliding across the cross braces... I jumped back away from the lift.... as the Customer exclaimed "Watch My CAR!!"... Everything was at a "ALL STOP"... and I stood there wondering how I was ever going to get this customers car safely back on the ground... After I calmed down... I called Ben Person in Arkansas. They put a "technician" on-line... I explained what had happened..... cute little ass walking by and all.... and he said; "no problem, just go out and push the UP button and raise the car back up... then make sure all the STOPS are up and let the car down". I told him I was not intending to get too close to that mess, because I was afraid that it would either fall on me, or go through the side of the building. He said; "then take a broom handle, stand back and push the UP button... I will give you my word that if anything happens, other than the car returning to the full up position - then coming down properly - Ben Person and Company will pay all damages". He added the fact that he was the lead engineer there - and that lift had 4 times the strength required in every aspect of its design build. He also said he was one of the Principle Owners of the company.. So I took a boom handle - stood back - and pushed the UP button. Among much loud creaking, screeching and popping... the car did in fact return to the lift's full up position... and all four posts returned to their former unbent state. I put the STOPS up and let the lift and car down... The Customer, now some three hours into this venture... exclaimed "I'll be damned!"... "if I hadn't been here to see that - I wouldn't have believed it." Needless to say, there was no charge for the work on his car... Two days later the man from Ben Person was in the shop to inspect the lift... and find out why one stop had failed to retract. He OK'd the condition of the lift ... and three months later a service team from Ben Person was in the shop installing a new mechanism for raising all the STOPS.... At that point I found out that I had two of the first twenty 4 Post Lifts they had designed and built for the Muffler Shop industry... Bottom line - don't buy a lift from anyone that hasn't been in business for at least 20 years. Don't buy a lift from anyone that builds their lifts outside the USA (to avoid product liability suites)... Don't PAY for anything purchased from ANYONE until it is delivered to you (the exception is when you are dealing directly with the factory, that has been in business for at least 20 years). Way too much FRAUD with retailers and re-sellers or "factory rep.'s".... If they don't have the working capital to order and deliver your lift - prior to payment - RUN... FWIW, Carl Carl Beck Mad Hatter Muffler (lost a lot of money on that one...) Clearwater, FL USA http://ZHome.com
