Thanks for the the feed back
Greimann: My plan is to use a GM 350 crate motor with 10:1 compression, 355 HP, 405 torque, weight of 78 Z coupe @ 3200 lbs, T5 trans, 225/50/16 tire/wheel size
I have an open R200 with a 3:90 ratio that is in need of a rebuild. With my plans for the above engine trans combination I only want to build 1 rearend. At the cost of a limited slip from MSA at $780, plus ring & pinion at @$450, add another $200 for bearings & seals and then labor to get is assembled: this is money I want to spend once.
Knowing what the RPM at highway speed will be will help me pick the correct combination.
If you could run numbers for 3:54, 3:70, 3:90 & 4:11 and let me know what you get that would be great.
Thanks
