unbreakable
Everything posted by unbreakable
I have one that runs but needs minor body work, solid frame email me at dayroe2@yahoo.com 1200 takes it away, need to get a truck don't have time for a toy at the moment
I need a driver side outside door handle and all the mechanisms that go with it. hope someone can help me out, thanks
My sender took a poop on me, aswell as the gas tank so i have a fuel cell coming, it has a gm style sender 0 ohms= empty 90 ohms =full, i need to find out the ohm range for a 77 280z, any help finding the answer would be awsome, i would measure mine but it doesnt work
WTB: 240Z, 260Z around PA and tri-state area
unbreakable replied to CrimsonPhoenix's topic in Cars Wanted
lol too funny we have been emailing back and forth , you still havent gotten back to me, i just bought a fuel cell for the car too. -
argggh to bad you have a prelude , i would trade my 77 but for a truck or something else rwd. Mine has minimal rust solid floors and frame, but i would let it go for cheap pm me if your interested.
i have a 77 i will let go for 1200 thats min. and i can deliver to you, for 200 bucks. needs a fuel tank an. driverside outside door handle, and other misc things fires right up if you want pics pm me
OK so i am working on a friend of mines 78 280z, he wanted me to intsall a aftermarket fuel pump he went with the walboro 255, external pump. I installed it in the stock location in the stock brackets. Put the power and ground on , primed the pump, turn the key heard it run tried to start the car, started and ran for less than a minute then died. Cranked and nothing no fuel, primed it again and same thing happened. Does the new pump need a new heavier relay to stay running, i burnt up my magnetic test leads running the pump on 12v. If any one has any suggestions that would be great !!!!!
i also hate pulling stuff off at the yard, i need to get my hands on a entire z31 or z32 rear subframe , thats going to be fun to do on my back !!!
yea i guess im fishing a little bit lol, i actually need to find out again what my 5spd is from, when i got the car for free!! it already had the 5spd in it. so now i just need to determine the year. A custom cradle for my swap will definitly be used, an im trying to think of a way that i can convert to dry sump, maby make a kit and sell it. Any machine shop can put a different bushing in the trans to make the bearing hole bigger or smaller, i just thought it would be better if i didnt have to go through all the nonsense and just bolt it up and go.
so you guys are saying my 77 280z with my 280zx 5spd will bolt directly and work correctly with the ka24de with out any mods?
ok i was told something totally different, in order to retain the stock l28 5 spd, you would have to pull the 56mm bearing off the counter shaft and replace it with,62mm one, the ka transmissions bell housing has to be used,but there is a problem the 280zx top shift rod is 14mm in diameter, but the ka bell housing has a 16mm hole for the 71c larger shaft. only the 1st/2nd shift rod was enlarged to 16mm, the other two are 14mm; The same as the 71b, bu
i just have a quick question, whats the wheel base in the rear of a 280z compared to the z31 and z32? any wider, are the mustache bars different? and if the wheel base is the same why not just swap the rear subframe an all into the 280z, best of both world disc brakes, better rear, so on and so forth. If i am in the wrong thread please direct me to the correct one!
very true, its basically a front clip not a whole car, but maby i should post there aswell lol. if no one on hybrid wants it i might have to sell it to a yard
i need a complete ka24de setup, engine trans, ecu, and harness must be 5spd. i will either buy it from you or trade you a complete 05 mustang gt setup plus cash on your part.
Hello, every one at hybridz.org!!, My name is Simeon, Me and My partner are holding a rally october 21-24th, its a 5k buy in, first prize is 150k, second- 25k third 5k, it starts off in oaks p.a. and ends at an undisclosed local in C.A. clues to the final destination will be given out at the check point in Phoenix A.Z. for more information or to sign up email Simeon@thebandittour.com, and spread the word, this is not a race of speed its a navigational/endurance tour any one can win! there will also be a car show during the 24 during the day an a massive party that night !! check out the website, more information will be posted on the site during the next couple of day Thebandittour.com
would it be more cost effective to make the parts out of fg then lay cf over the fg? just a thought, i wanted to do my whole car that way i needed 57 yards or so, i found it for like 2400, then my friend that does interiors said he can get me the materials for 1200 or so. basically it would be a carbon wrap, no weight reduction but would look sinisterly cool lol:flamedevi
Has anyone used or seen this airdam used?
unbreakable replied to BurnoutZ's topic in Body Kits & Paint
the anticipation is killing me !! -
sorry for the noob question but i need to repair my inner fender well on my driver side , do they sell a pre cut piece of steel , and if not what gauge should i use?
the top i wont want to recreate lol, the if you take a look at a stock z's back end and this rear , it looks like molded flares , lots of fiber glassin to do , the headlights i wont be able to recreate either but i will try and do something very very similar to update the look
and yet no one said the black rendering looks like an aston
its going to be a while lol im not made of money unfortunatly!
ok well i want to try an do the concept, but it will be based on the original body and im using a 77 280z ,basically ill try and make the mold the best i can because no where on this thread are any of the dimensions. and im just crazy enough to do it with a whole lot of help from my local body shop and long sleepless nights. the front end seem extremely do able, but the louvers and the tails not to sure on that yet unless i find suitable tails lol and im not to keen on the louvers anyway, but from the pictures it looks like the widend the body so ill make molded fender flares, and yea permission would be nice but ill just do it any way, but i dont know if i can get it exact , just because its not my design.! ill try and keep posted and take pictures first things first stripp the 77's body , i have to wait for my tax return though ;(
god i wish i was better at doing body work, i most definitely want one but mine can be a rough , i plan on covering it in carbon fiber as well as the rest of my 77 !!!!!!
