Hey all, got my MS2 all soldered up and things were looking pretty good. Until i decided that i just wanted to control fuel at first... So i had the board set up for VR ignition at first but decided that i wanted to go to a turbo dizzy instead, at that point i priced said dizzy and decided that at first i would use the negative term of the coil for my initial learning curve and just control fuel. So i added the circuits required to run the -coil lead and the jumper changes to go over to the hall/optical input. When the VR circuit was hooked up i had almost everything working in the tune studio when i moved the pots on the stim. After the hook up of the hall/optical circuits i had the opposite, nothing would change when pots were moved. Although when i unhooked the stim, moved the pots, then re connected the stim the values moved in the tuner studio. I started running through troubleshooting and got most of the way through up until looking for pulses out of the cpu pins 21 and 22. At those pins there is a solid LED on the tester and solid LED at D14 on the ms board. On the stim the PMP light is on bright. I never did get any tach signal to the tuner studio even before the changes. I have pulses from the stim at the "Tachselect to OPTOIN" jumper. I am driving myself crazy here, i am not an electronics guy so i feel a bit like maybe i screwed the pooch!! Anyone got any idea what the hell i did???
Thanks,
D~
