Hello all, long time, no see. Which is good since I typically only come here when something is bad... anyway I've got this problem, see?
Started a bit ago, a little trouble getting the car to start. Classic *click* when I'd turn the key. Checked wiring on my starter, since one has come off in the past leading to this problem... not this time. I rock the car a little in desperation (I'm on a dirt road, quite far from civilization at this point) and somehow it starts up. Whew, I think.
I get home. Try turning it on again? Click. all wires connected. OK, must be the battery. I get a jump from a neighbor, run it for a while and I turn on the lights to see how it's going. This kills it. Well. Not going to bug the neighbor again, wait for my girl to come home. Jump it, run over to the neighborhood Napa. Guy comes out to test the battery and alternator. He says battery is bad, alternator is good. I had to jump it to get this tested.
Jump again to drive over to AutoZone because I still have the battery under warranty until March (Bought it just shy of two years ago). Guy verifies battery is no good, I replace it, but not before brushing the cables free of any possible corrosion. Car won't start. I jump it to go home because I don't know what else to do, and I need to get to work asap anyway at this point, so now I'm borrowing my girl's car for work. Thanks babe!
But still not sure about this car. I have a multimeter that I am a little familiar with, use it to test the ground, and it's good. I jump it again and decide to just run it a bit to see if the battery was just dead from the store (it had almost no charge at this point). I run for a little bit and LO! There's smoke coming out of the dash vents on the driver's side! Electrical smell. Great. I'm about to pull the dash apart, which I've never done before and am not looking forward to because my best guess is a short somewhere in there. It's not a well-educated guess. Any ideas?
Car info:
'73 240z with l28 and upgraded windshield wiper motor ('94 Accord, I believe) and upgraded MSA fuse box, both of which were done over two years ago.
no radio, no A/C, no heat connected (core just sitting there) and none of that has been changed/touched in years.
