patrickhove
Everything posted by patrickhove
I have the same dash and am at the same point. I really want to put the speed hut ones in but im not sure how the extra room will look. So please post a pic if you do it.
I need the rod that connects the door handle to the door latch. I managed to misplace mine. It is the drivers side. Let me know what you want for it shipped to socal. Thanks Patrick
I need a lock set for my 240z. I would like a full set including both doors rear hatch and ignition with a matching key. I dont really need the ignition but it woild be a bonus. Let me know how much if you have one. I will need it shipped to san diego ca. thanks
I have a 1970 240z and need a set of door locks with keys and a trunk lock all matching. If you have a set in good cond let me know what you want for it shipped to san diego ca. I also need a set of headlight buckets in good shape with all studs intact. Thanks Patrick
i need a drivers side window regulator that is in good shape with spring in tact. If you have you dont need let me know how much. thanks Patrick
sounds like a deal please send me a pic of the part and a paypal invoice to thompsontkk1970@yahoo.com Thanks Patrick
If you want to sell it let me know how much.
I need a 240z drivers side window regulator. I have lost the spring for mine and finally it is time to get it replaced. If you have one in good cond please no crap i have crap, let me know how much shipped to san doego ca. thanks patrick
I need a 240z drivers side door in good cond. If you have one you want to get rid of please let me know. thanks Patrick
I need a r200 long nose with 4.38 gears or a 4.38 ring pinion set. If you've got one please let me know how much. Thanks
how much does the gtx30 run. looks like the perfect setup. I have been waiting to see the gtx in a turbo small enough to use.
I just put some 23" tall tires on my car to help cheat my rear end ratio. now I have very little ground clearance in important areas. what do you guys think is too low. im down to 3" on my skid plate. This is a street car and im not sure at what point I should be worried about smashing things.
btw it is a rear wheel hub
I have a 240z that i am installing some wheel studs in. I have noticed that I am missind a metal collar that rides on the shaft of the hub. it is about 1 inch in dia by maby 3 inch. Im not sure what this part does but since it is in one side of the car i am assuming that it needs to be on the other side. If anybody out there has one they would like to sell please let me know. thanks
sr weighs 200# less and most parts can be found off a nissan sentra ser or 240sx. but overall if crazy hp is what you want get a 2jz
I was getting ready to section my 2 front struts and I noticed that there not the same. I know there is a right and a left but mine are different otherwise. one has a thicker cast flange the caliper bolts to and is a little taller about 1/4 inch. also the spindle axles are different one continues after the threads stop about 3/8 inch. my car is a 1970 and I have seen all sort of not quite correct factory parts is this part of that. Were these this inconsistant or is one of my struts incorrect. anyone out there seen different struts in the 240z. thanks
thanks for the good info got it taken care of.
im looking for 1 rubber isolator off a 240z. the rubber piece on the top of the strut with the 3 studs. Please let me know if you have one you want to get rid of. I actually only need the spacers on the under side. I have finnally found out why my car is crocked now I cant wait to drive it. hopefully someone has one. please let me know how much shipped to california. thanks patrick
its too late for that I likr to do everything the hard way so I allready ripped my donor diff apart and have the ring and pinoin in hand. The diff caps and misc parts were all thrown in a box so im a little leary about just putting it back together now if it matters that the caps go back on the same spot. So as far as I can tell im now stuck with putting the gears in my r200 with lsd in it since it is still in tact thank goodness.
i have a r200 clsd from a 87 300zxt. I just purchased an r200 with a 4.1 ratio to swap gears. my question is can I just yank off the ring gear and bolt it on(pinion too of coarse). I see the bolts are a different size but is there any clearancing on the gears that needs to be done. thanks
im looking for some fiberglass fenders stock style not the huge flared ones. let me know if you have a pair you would like to get rid of. thanks
im looking for 1 rubber isolator off a 280z. the rubber piece on the top of the strut. Please let me know if you have one you want to get rid of. thanks patrick
I have a 1970 240z that has an sr20det in it. I am having a suspension nightmare. I have installed tokiko illumina shocks and some gc coilovers. some how I have managed to do something to make the rear of my car about 1 inch off side to side. I have to crank the left side coil spring up an extra inch to level the car. at first I thought I put the control arm on upside down but Im pretty sure thats the way it goes. so it seems I have to take apart my suspension and I was just thinking of replacing it with azc coilovers in the process. I cant find any info on these though. only people who I sawnever used coilovers. I see many people making there own kits Im not sure If this is to save money or it it going to work better. I have the azc brakes and love them I just ordered their front control arms also. i have the techno toy rear arms ready to go on. What is going to work best for me I plan on driving this car to work only 5 miles and race it on the weekend. the azc just seem easy and cheap since I need the camber plates anyways. Please give me some input on what works. thanks
I need some gears for my 240z project. It's got an 87 zxt r200 and I have quickly found thhat the 3.7 gears are not nearly steep enough. If anyone out there has any sort of diff that contain the gears i need or a set of gears please let me know. thanks patrick
i really need to get my revs up. i have a r200 from a z31 300zx with 3.7 i think. i need more gear does anyone out there havee anything. thanks patrick
