Toni L
Everything posted by Toni L
  1. 17 x 10" ET0, 245/40 R17 17 x 11" ET-25, 275/40 R17
  2. Sun shining. That´s basic white colour, painted in my garage
  3. I bought eletronic power steering assistant and new upper steering column, but this might be later project. More electronic work: New wheels and tires. Image BBM 17x10 & 17x11 and Toyo R888 (not together yet) And something else:
  4. I have spent time making electronics. Fuel pump control: Made engine mounts stronger: More electronics: New turbo. Watercooled Holset 71.5mm / 80mm #22. Something like 900hp turbo compared to previous ~750hp. Fuel pressure regulator: And something else.. New battery bracket etc.
  5. Thats close Same thoughts about bodykits. Front air dam and small bumpers is the best..
  6. Yes still doing that after many years
  7. Battery isn´t installed yet. That plastic thing would be only cover to avoid electric shortcuts, but maybe I change that when I´m doing it. Someone asked about those Wilwood calipers earlier, but I ordered from here: http://www.rallydesign.co.uk/product_info.php?products_id=11370 I can´t recommend before I have driven my car, mut it feels that mechanical handbrake got enought power for parking brake. (maximum vehicle weight 750Kg) is mentioned, but I don´t know what is REAL problem when caliper is made from basic 4-spot Wilwood Powerlite, and hydraulic braking power is enought. With those disc width 0.35-0.50" or 0.79-0.86", it is not a real "racing car" caliper for sure. I´m sure those can be fitted to 15" wheels. My current setup is 278x10 mm rear disc. Caliper adapter is my own design.
  8. Brake lines are ready and mechanical handbrake works too. Got windshield now and installed also wiper motor (from Vw Scirocco mk2). New custom cv-axles.
  9. Ok, that will help a lot. I believe it was here where I read different information.
  10. That is the problem. It's not same and I can only find winshield for coupe.
  11. Does anyone know place where i can order windshield for 260Z 2+2 -74? Thanks.
  12. All the brackets done (ic, radiator, oil cooler and front bumber) I made also tow hook (red) I got some parts again. Brake hoses, New Hub for carbonetic clutch and R154 transmission, New door locks and ignition switch and some smaller things.
  13. Perfect fit Now i have to make all brackets for Radiator, IC and Oil cooler.
  14. That was Works Engineering tank from Ebay. I believe it can remove air bubbles too. I will be using Koyo radiator from Skyline(?), thats not best choice because I had to make more space. I got also new fender emblems
  15. Got some new parts today. Custom made IC, radiator overflow tank, oil catch tank. heatshield for turbo and some smaller things. Emblems look good after painting. I disassemble one pair of Z31 CV axles and have to make shorter axles. With 300ZX Z31 stock rear hub flange it will be about 50mm less / side.
  16. Before: After: Cleaning rest of engine parts And painted door handles and emblems.
  17. Rear-side windows ready Now test fitting doors and mirrors.
  18. Started it again more pics at http://toni.dnsf.org
  19. 120-9463 http://www.rallydesign.co.uk/product_info.php?products_id=11370 I dont know what special model that is.. If it makes my car street legal it´s OK. For more braking power i might need hydraulic handbrake..
  20. Engine assembly started: http://toni.dnsf.org/gallery3/index.php/QMG_7886 http://toni.dnsf.org/gallery3/index.php/QMG_8728 WRC-style intake manifold ready with Bosch EV14 1000cc injectors. http://toni.dnsf.org/gallery3/index.php/QMG_8717 And some other parts.. Ati super damper, TT headgasket, 264/9.35 camshafts and camgears, wilwood calipers with mechanical handbrake http://toni.dnsf.org/gallery3/
  21. I haven´t done that yet. 280ZXT cv-axles should be bolt on, but those Z31 cv´s require shorter flange to hub (I think?). Something new.. New aluminium floors http://toni.dnsf.org/gallery3/index.php/OMG_5466-1 Engine parts http://toni.dnsf.org/gallery3/index.php/OMG_5528-1 http://toni.dnsf.org/gallery3/index.php/OMG_5530-1
  22. Inner housing is bored to same bigger size 72mm, when it´s possible to fit 6306 type bearing (ID = 30mm,OD = 72mm,T = 19mm). With those Z31 rear hubs.
