HowlerMonkey
Posts posted by HowlerMonkey
Lexus SC300 tranny is five speed.
I think I recognize 2manyZ's diff with the torsen as one that was originally in the 300zx cars bought from leitzinger and sold to Datsun Dynamics in the early 90s.
Some early vg30 pickups had carbs but most if not all are in australia.
I got my tranny from a 2 wheel drive pathfinder and it uses a shifter that comes in where the plate is but some things need to be added as well as changed if I wanted to mount the shifter where it is for a Z32 (1990-1996).
Funny but there is only mention of inline six nissans in this thread and a first generation maxima is a inlline six nissan.
Did someone write "R200" in invisible text on this thread because I'm just not seeing it?
Also.........many pre 1981 280zx came with 3.7 R180s.
In 20 years at various nissan dealerships, I have seen many.
First may have been the 1986 pulsar SE with the 16 valve.
His is an 81 so he will need the crank angle sensor that mounts on the A/C compressor bracket................and the dropping resistors........as well as the fuel pump controller that comes on 82-83 cars just to make it run with that ecu.
Best to find the correct ecu for that car.
Most if not all FS5W71 I have seen only come with the spring against the gate for reverse/5th.
If you want a shifter where the plate is, use the pathfinder stuff.
I'm building a L28et in a infinity M30 and are using the shiftter coming out of the cover.
Who needs a short shifter when you can have a long shifter and be really cool?
So how far did you have to move the tranny forward to clear the crossover pipe behind the engine?
Maximas as well got 3.7
Thread a bolt into it,the bolt will push out the bearing(bushing) its brass and soft.I used a puller though!
Sweet............been working on Z cars for 19 years and never tried that.
Mazda second generation RX-7s have a muffler bearing.
Don't use the one on the last exhaust stud unless you put that stud in yourself recently.
If you're using the L28 harness, did you get the fuel pump controller used in 1982 and 1983 cars?
What year harness and engine?
Sweet............my dad did flight testing in hawaii during the 60s on remotely piloted planes for the purpose of nuke delivery.
Kind of a remote control cruise missile but far safer than lobbing a nuke from your skyraider.
I used to work for a recaro and flofit dealer in the 80s and I remember the 240-280z seat track application from recaro stated you used the passenger seat rails for the driver's seat and vice versa.
Recaros and flofit will fit.
Charade is 1 liter and similar to but not the same as the chevy sprint and isuzu 3 cylinder turbo cars.
sweet and elegant solution.
I would carry a spare serpentine belt tensioner pulley, though.
It's the oil drain that usually causes problems since you can't get oil to the turbo if it won't drain.
Stock setups have a 90 degree angle before the barb on the pan and this is where coked oil likes to hang out which eventually clogs it.
I had one with 200k miles and the original owner claimed it was getting noisy. I cleaned up the drain and checked the supply line, kept good oil in the car and made sure never to open the throttle much until the turbo had reached operating temperature.
It was still working at 300k miles when I gave the 84 slicktop to datsun dynamics.
I shoved bearings into and cleaned one that had lots of shaft play, put it on my 1984 maxima, and used the same driving technique when cold and it's still going strong 30k miles later.
Here's one that's sweet.
LOL.......my answer implies to keep the L24e and turbocharge it.
Drilling the block to front sump a L28 is a lot more labor intensive than making the pick-up marginally longer and re-routing it.
You also must drill a new dipstick tube and, since the oil gallery goes through nearby, I recommend not drilling the fake small boss found on L28 F54 blocks because it is far too easy to hit the oil galley.
Far better to drill elsewhere.
I'll try to fix this post since pics were moved.
Here's how you solve the oil return problem without taking out the oil pan or removing the engine.
I've used this many times over the years on 280zx and when fitting turbos to a few rear drive maximas that have front sump.
So.......19 years later, I finally do a quick write up with pics.
It doesn't work on all engine configurations but I will see if I can do it on my M30 soon enough.
You start with an oil pickup tube.........or two.
A bench grinder around the periphery makes that pesky screen disappear with the quickness.
Notice the fact that the tube will protrude into the pan which keeps as much oil as possible away from where it meets the pan.
Now you use the shortest drill you can find and fit a cut off bit for the starter hole that will allow a unibit (stepped drill bit) to gain bite and then drill to the proper diameter. Unibits have come a long way and their being short is a big plus in this case as I was able to use a pretty sizeable drill and still be able to do this on the car.
Use a rotary gasket grinder to smooth out the pan where you will be placing the flat side of your new flange as high as possible in the pan so thit it is not submerged when the pan is full and cut a relief if necessary but you want as much real estate in which your sealant will lie. Some obsessive compulsive types could fit a large diameter O' ring since it looks like you could fit one easily. I did not use one this time.
Test fit it to the pan and drill however many holes you want to hold it to the pan and then use the fact that you now have two holes in your pan to remove any metal particles by spraying brake cleaner with the wand to get them out of the pan. Maybe some worriers could use a magnet to confirm everything is good before finishing the install.
Then use some self tappers in stainless steel to tighten your flange to the pan with sealant.
I used the rest of the tubing from this one to weld onto the end of the stock turbo drain tube so it would allow me to use the stock nissan oil return hose (silver).
And here is the finished turbo drain tube and all parts used were genuine nissan save for the self tapping screws.
Still going 30k miles and 1.5 years later with no leakage.
Notice that there are no sharp 90 degree corners like the stock offerings which allow coked oil baked from heat soak in the beariing housing to accumulate and eventually clog it.............all smooth curves.
Feel free to post it anywhere but it's name is "HowlerMonkey flange".
That custom manifold is sweet.
Has anybody tried the LD28 manifold as a starting point?
My Z needs a 7mgte
in Toyota L6 Forum
Posted
I've got the entire engine management system minus the coils with two ecus........one has a superchips mod but I haven't put it on the simulator here at standard's ecu division to compare it to a stocker.......which I also have.
If I cannot adapt it to run 550s on a L28et with the LS400 air flow meter I will sell it.
I was limited in time but got most of the harness and most of the peripheral stuff other than a few relays that are spread all over the car.
