Definitely stay away from the US VH41... its nowhere close to the US VH45 and JDM VH41.
90-93 had the plastic chain guides but when you go to Infiniti to order them, regardless of the year you say, you'll get metal backed guides now. 90-93 also had the siamese ports... though, I haven't seen anyone claim yet which is better. I'd the oval port would probably flow more in the end but I'm not positive. I like my siamese ports personally.
94-96 VH45's had the oval port heads and metal backed chain guides. There were a few other small differences between these and the early VH but overall the same except for the 96 VH, which lost the variable valve timing.
On the JDM VH41, I believe they have the alternator between the heads and do also have the duplex timing chains. That would be stronger... though, I'm not sold on the duplex setup as it would only add more weight to a system that already works (though, that could just be because I like timing belts more... I hate timing chains period). Anyway... from what I understand you can actually put the VH45 crank in the VH41 to get your 4.5 liters. I can't remember if you retain the duplex chain setup or not though. Mettler over at NICO is the guy to go to for JDM VH41 info.
