zmyz?
Everything posted by zmyz?
I was told by a life long mechanic friend when I rebuilt an engine in my z to drive up to the mountains and cost down as many long grades (in gear) as I could for a few days to fully seat the rings...
If you get a z31 and have no idea when the timing belt was changed last, change it along with the cylinder head temp sensor... Interference engine... Also their is a federally mandated campaign for injectors if it hasn't been done yet.
Between 500 -550 depending on what's installed like flywheel, exhaust manifold ect. When I pulled my 7m it was about 540 including the turbo...
Well I have a bit of a history with z's, at 25 I've had six z31's, one s130, and one s30... It started with a light blue 84 I got from an old guy for cheap to fix and never did... I got distracted by a red 85 I snagged because it needed an ecu. When I threw a rod in the 85 I got a maroon 88 with really low miles and got rid of the others. I still have the 88 and completed a na2t at the 55k mile mark. Over the last few years I traded a Honda mc for an 86 to fix and sell, traded a Kawasaki mc for an 87 that I didn't keep either. And picked up an 89t that had a funky title so I parted it and kept the turbo stuff. With the cash I made off the 89 I picked up an 81 cb750 that I ended up trading for an 83 280zx, and with the cash I made off the 87 I bought a corvair. Well I got the itch for another bike so I traded the 280 for a ducati and ended up trading the corvair after (3 years of restoring) for a 74 260z. So that is a really quick 10 year fast forward leaving out a few Porsches, mitsu's and a few more boring things... I currently still have my 88 na2t, my 74 that I'm going to fully restore, a 94 ducati that's also a keeper, an 86 and 87 Porsche 944 and 924s and a new mazda 6.
Well I think I have the beginning formula, breaking it down degreasing & painting... Checking all bearing clearances and the cylinder bores. Picking up the appropriate size flat top pistons (planning itm) And Paired with a 275 duration / 480 lift cam (any ideas)? I will also smooth out the castings of the head and port match. Of course gaskets and bearings if needed. And rebuild the su's with a jet kit... About to check out what kind of jets work well. A decent 160-200 hp?
Look I'm not trying to piss off the staff, actually I've seen forums where the admins are MIA, non existant or just couldn't give a $. And trying to research problems or rustle up help is enough to make one mad so I appreciate you guys. Actually one of the main reasons I got rid of my fc! I am here simply to find help / parts and contribute anyway I can, not to cause problems. The location thing after the few years of being here just really rubbed me the wrong way and actually caused me to break rules with my job... Also I didn't realize other languages would be a problem / cause the reaction? And where I'm located you just about need a second language, so I have learned what I need too. Sorry for being a smart Ã**, maybe I just needed cafine or nicotine or both?
Going back with the stock green. The wheels will do until I figure out exactly what I'm going to do with the suspension. I have seen snowflake wheels on late s130's that I might try to get ahold of? And on another note thanks for the suspended account admin! I really appreciate the roadblock in the research on hybridz. So was I suspended for NOT displaying where I live in the Profile I've had for years? Or for saying it was donky crap (in misspelled spanish) that I had to do it? Because my error was not plainly stated...
N47 is open and I know the p90 is a good performer but I hate to rip the head off a perfectly good motor and from what I have come across the p90 will not give me as much compression... Plus I'm thinking of building the turbo motor later when the quest for more power continues... And as far as the warning for no location that's some burro mireda...
So I finally got my hands on an early 74 260z. I've had several z31's and an s130 so I'm not new to the z game... I just have some things I need advice on. I received a solid rolling chassis, boxes of parts and one l28 na (n42 block and n47 head) that has an l26 intake and what looks to be earlier SU carbs. I also received an l28t (f54 block and p90 head) that's missing the turbo but not down pipe... I was told both were good engines turbo coming out of a wrecked car with right at 100k, and na being an l26 (incorrect) that was a fresher bottom end. So let me drop in a few pics to keep some attention... Original color, Ok now for the questions, I'd like to build the na block with higher compression. I'm coming across conflicting info... Can I pick up some flat top pistons and that up the compression to around 10 to 1? Along with a lumpy cam (not so much to sacrifice power or push it to far up in the rpms). Also some port work on the heads with some valve seats/seals. And of course a full gasket kit, timing chain and bearings if needed. I've read the block is fine to build and the head is an ok flow'er plus I'm not looking for anything wild. I'll figure out what I will do with the l28t later. I'm aware of the potential just have an 88 na2t z31... The usual places for parts are turning up null. Recap, Pistons where? ITM can be had on eBay, good/bad? Compression numbers with nothing but flat tops... Cam suggestions, supporting mods? N47 tricks? Parts sources... My z31
http://www.xenonz31.com/computerpinout.html better one plus the plugs should be all you need...
Is this any help? http://www.xenonzcar.com/z31/computerpinout.html There is another site that has more detail but I cant find it at the moment...
1987 300zx Turbo Convertible I found for sale.
zmyz? replied to 19762802+2's topic in Z31 Series - 300ZX
Looks to be an auto... I couldn't do it, but its a nice example. -
Hey dude I'm in NC and I will sell my spare harness... I also have lots of spare parts such as a block and crank, eccs with injectors, flywheel and some other random stuff. funky300z@yahoo.com
agreed! I need to shoot em an email and see if they make flares for other z's...
Starion/Conquest Wheels? Will they work?
zmyz? replied to rustorbust's topic in Brakes, Wheels, Suspension and Chassis
I have a set of these on my 88 z31... I don't know if they will work on a 280 but the backs stick out past my fender like a 1/4 of an inch. It really gives the car a unique look, and I get compliments all of the time though. Most people think they are celica supra rims. And if your suspension has the shitty design like the z31 you will scrub the side walls a bit at wot from a stop. Spacers required... -
Its a couple of pages in and i don't mean to high jack but all the z's exhaust I have smelled besides the 350z is extremely sweet, as is my z31. Does the rb series have that exhaust smell i have come to love?
Ok so I bought a r32 front clip with an rb20det in it. It also has the 4wd trany. The plan is to put it in my 88 z31. Would i be able to use the bell housing off the 4wd and my stock z31 n/a trany? I have read I can use the z32 and a 240sx trannies but thats all the info i can find... I don't recall racingjitter's write up saying what trany he used, and his is the most detailed i have come across? Anyway I was kinda hoping to use the stock one and possibly the stock drive shaft. Any insight on this matter would be greatly appreciated!
