Jss240z
Location
Ontario , Canada
Jss240z's Achievements
0
Good explanation. Thanks
Right , reading the posts again a bit SLOWER I guess if the spacers are matched to the hubs they could be any length and completely different. Sorry for asking that multiple times
Does anyone have a new spacer that they can measure the length?
I made sure to get Oem bearings. Skf brand. I'm own a machine shop and definitely know that cheap bearings are NOT good. Now that I think about it some more I do remember that same wheel being a little harder to turn before I changed them but didn't really think of it a big deal because the wheel was on and obviously easier to turn as opposed to trying to turn the hub.
I did not measure the spacer. I don't know what the length is supposed to be anyway. Does anyone have that measurement? I think the seal is seated because when I have the flange installed without the nut it turns free enough. The second I put the nut on and torque it a bit is when it gets tough to turn. So I'm looking looking at a spacer replacement? Is there a difference between the length of spacers drivers side to passenger?
So while swapping my rear diff I got into the while I'm at it mode and decided to replace my rear wheel bearings. I followed a good write up that another site has. Everything is together now but the drivers side is tough to turn. One hand can JUST turn the hub. Has anyone else had this issue and how did you solve it? I'm thinking it must be the spacer between the two bearings but wanted to check before I did just in case there might be something m missing. As always, any help is appreciated!
I did NOT degree my cam second time around . I shaved another .020 off head to bump ,,CR and thought it would need another bump in advance valve timing. Degree your cam! Judging from the results I have gotten it is very much worth it. Actually retarded it 4 degrees from cam card and made a WORLD of difference. Especially at top end.
I showed the picture to mike at whitehead performance here in Ontario and he said it looks like some kind of cheap locking device but not completely sure and that he is used to seeing them open like the pic on the right (3.9). Still going to put the 3.9 in and yes for sure i will check for wear before swapping. Thanks for the suggestions guys.
- 8 replies
- R200
- differential
(and 2 more)
Tagged with:
Ok, I realize that's what it is but the rectangular piece in the centre?
- 8 replies
- R200
- differential
(and 2 more)
Tagged with:
Well when I spun the wheels when it was in, one went forward and the other back. So it must be an open diff right? What I'm really trying to get at is do I need to swap it into the 3.9. Plus knowing what is is would be helpful.
- 8 replies
- R200
- differential
(and 2 more)
Tagged with:
Great info. Went outside to check again and it looks like there is only one rod going through the centre like my 3.9, but with that rectangular piece around it. If it's only one is that still considered a four pinion?
- 8 replies
- R200
- differential
(and 2 more)
Tagged with:
So I decided to remove my rear diff which is a 3.7 and install a 3.9 I had laying around. When I romoved the back cover on the one I removed from the car I noticed a little piece in the centre (first pic) that the 3.9 I planned on installing did not have(second pic). Does anyone know what it is? Some kind of locker?
- 8 replies
- R200
- differential
(and 2 more)
Tagged with:
Yes, that's kind of what I mean going for. Except not so much the foam ones. Reading here on here it seems like some people have had problems with that foam type getting soaked with fuel . Now the ones I have now do have some fuel that gets into them sometimes but the thought of foam gets me nervous. In my head I have a picture like this, but with an actual filter on them. Kinda want the looks and performance . http://toyheadauto.com/PerformancePages/PerPics/Air_Horn_Screen_Filters.jpg Actually thinking about it , has anyone used these and added their own cotton type filter screen to them?
I should clarify that the filters I'm speaks of is something that doesn't cover the whole air horn. I would like to show off what I made a bit. Currently I have a k&n that covers both horns on each carb.
Absolutely. For the right price lol. Have about 8 hours in them ( programming, set up and a couple scrap trial parts) so unless they aren't made, probably cheaper to buy from someone who makes lots at a time.
