240Z28
Everything posted by 240Z28
Moser Engineering Mark Williams Enterprises Strange Engineering I am sure there are others; these guys are well known to the drag racing world.
My Complete LS1 Install Documemtation with Pics
240Z28 replied to a topic in Gen III & IV Chevy V8Z Tech Board
Scott, Sounds like something all of us contemplating the LS1 install needs to have. Thanks for taking the time to provide it to us. Please email it to me at epfmotorsports@cox.net Thanks. -
Jack46, I haven't even thought of how I want to configure the fuel system. I guess I need to start thinking about that along with everything else. Right now I'm just starting the short block; dropped it off at the machine shop last week. I've already got the Q45 rear and 2 sets of halfshafts. I can't imagine putting in a 9"; even though it will get mostly street and drag use, for my needs the car must remain IRS in case I take it to an autocross or road course for a track day. As far as headers, I know someone who makes custom headers as a hobby. I plan to get him to make a set for me once the car is done. With all the research I've done and all the posts on this site about crappy block hugger headers and long tubes scraping the ground I think a good fabricated set of step headers is the way to go with a psi motor. Later
Jack46, Let me know how your SC install goes. I'm curious how you mount it and run the intake lines. I'm going to use the Q45 differential setup. I don't expect to have much problems with the rear end other than getting it to hook the tires. Thanks.
I plan to add a vortech supercharger to my 240Z powered by a '95 Trans Am LT1 . Which Vortech kit requires the least amount of work and fabrication to install? Is it the F-body LT1 kit, Corvette LT1 kit or should I just buy the head unit and make the piping from scratch? Anyone have pictures of this type of install? Thanks.
Another option to using the factory ECU is to purchase an aftermarket fuel injection system. I bought an Accel digital 6 fuel injection(DFI) controller which replaces the factory ECU and wiring harness. These units are getting cheap these days as serious LT1 racers are upgrading to the digital 7 system. This system allows you to adjust the fuel and ignition at all rpms by programming with a laptop. Check them out at the Accel website. Just another option if you have the cash.
Hey guy's' I've just pulled the LT1/T56 and wiring out of a firebird for my 240Z conversion. I want to sell off the firebird body asap but don't want to miss pulling any parts I might need for the conversion. Any common mistakes or something I might miss? Do I need the braided clutch line? I'm going to want a/c, i may go with vintage air setup. If I keep the stock setup with GM compressor will I use the firebird a/c hoses? Thanks.
For those of you that installed megasquirt, how did you wire the injector 12v power feeds to the db37 connector. Did you use one wire to the pin 28 location and split downstream? If so, what gage? Thanks.
Fuel pump- Best and quitest.. please help!!
240Z28 replied to love-my-V8-280Z's topic in Gen I & II Chevy V8 Tech Board
I got my pump from Top End Performance. I believe it is a Bosch unit. I'm not sure of the model #. It was on the expensive side($200) but it is extremely quiet and I haven't had any problems with it in 3+ years on my injected car. Just another option. -
Nhra rules require a helmet for 12.99 and quicker so bring a helmet if you 're in the 12's to be safe.
Hey Mas, Do you accept Paypal? I need a set of those. Also, I need 1 more pair of Q45 flanges. Do you know where I might find some? Thanks.
Sweet setup, let me know when they are available and how much. So far I have the Q45 R230 and 1 pair of axles. I am planning and collecting parts for a full Hybrid transformation in my 240Z. [/img][/url]
Sounds like someone needs to upgrade to an R230. You'll sleep better at night.
Someone needs to strech that Lagonda and make it a limo. It should have plenty of power as those came with a V12 and would do around 180mph! They would also drain the account in the late 80's at around $150K.
Grumpy, If you have the time, go for it! I work as a construction manager for a large general contractor and yes you will save a LOT of money. Be prepared for a lot of headaches, problems etc. but when it's done you will have a big sense of accomplishment and will gain valuable knowledge in the process.
Hey Phantom, If you had to do the suspension over again would you go with rubber bushings instead of the poly? I need to make a decision for my LT1 240z project. I want my wife to be able to drive it to work every now and then and want to be able to take it out of town comfortably. I also plan to spend serious time figuring out the best exhaust setup. Did you install a crossover pipe?
R230 Q45 CV axles. Where did you get them shortened?
240Z28 replied to maichor's topic in Drivetrain
Denny, I'm all for that. I talked to a guy named mike at the Moser trailer this past Sat at the Strip at Las Vegas during the NHRA National event. He said I would have to send a drawing of what is needed and it would not be a problem. He is the person in charge of this type of custom work. If you already have something set up , thats even better. It would be nice to get the discount. The other option I was going to do is is order through Moderm Motorsports with their companion flange adapters. They charge an add of $310.00 for the moser axles. I'm not in a hurry to order, so lets see how many people need them and decide. Thanks, Errol -
Hey, I just scored an R230 diff & axles at the junkyard for my 240z project. What is the difference between the Speedway Engineering shafts vs the Moser units? Aren't the Speedway ones more expensive? If I go with Moser, does anyone know the Moser part# for the shafts so I don't have to send them a drawing of what I want? Thanks. [/img] -
Hey, Can the LT1 be installed even closer to the firewall than allowed by the JTR mounting plates? Has anyone changed the dimensions given by JTR to accomplish this? I want that motor as far back as possible! Thanks.
Thanks for the help you guys. I am trying to learn as much as possible before I start this project this winter. I am trying to get a deal from a friend on an Accell DFI unit to install so I can avoid all the factory computer and be able to program everything. He bought a Holley unit to replace the Accell that was on his firebird drag car. That will make it easier to install a supercharger later....maybe.
Hey Guys, I'm planning a '96 LT1/700r4 install in a 73 240. Does anyone have a comprehensive list of differences between the JTR install of a carb'd motor vs the late model LT1? I am not referring to the computer or electrical challenges, just getting the motor in there with the accessory/pulley setup, best radiator, fan, headers etc. Thanks for the help. 240Z28
I know of a used LT1 powerdyne supercharger for sale that came out of a 96 firebird. I have a 96 LT1 motor that will be going in a 73 240Z using the JTR method. Does anyone know if the mounting brackets and hoses that come with the powerdyne kit made for a camaro/firebird will work when installing in a 240Z? I don't really want to remake brackets and hoses unless I absolutely have to. Do the vortech or ATI kits have the required clearance? Thanks!
OK, I've got the sickness and I'm going to the next level. I purchased a LT1 engine/trans/computer combo on ebay to drop in a 240Z. It was listed as out of a 96 Camaro Z28. How do I know by looking at it if it is a 96 for sure not a 95 or 94? Do these motors have casting dates or serial numbers to easily identify this? Thanks!
