bco6
About bco6
  • Birthday 03/03/1987
  • Gender
    Not Telling
  • Location
    New York, NY
bco6's Achievements
Newbie
10
  1. I Research that the oil drain plug is the same as the gas drain plug, So I have an extra oil pan. problem solved...
  2. Hey team, Took apart my gas tank and resealed it months ago as part of a restoration and I misplaced the gas tank drain plug.... Looking to get one to NJ 07922. Thanks! Brian
  3. Looking for a set of vlsd cv axles that came in the Shiro edition 300zx turbo. PLEASE let me know if you have a set
  4. Hey guys looking for the Green Plastic 6 tooth speedo main drive gear, 1.13 inches ID and 1.73 inches OD from a 1983 Turbo Borg Warner Transmission. Any help is greatly appreciated. Please PM me if you have one!
  5. Pat1, I believe your car has the best Stance/ wheel combo. Do you have lowering springs with stock suspension components? or are you using coil overs? I recently acquired a set of rotas 17X8.5 +4 offset and have a early 74' 260Z with Stock suspension. I assume I will need to roll the fenders, will I also need to use spaces to clear the stock spring perches? Any help is greatly appreciated. Thanks
  6. Do those Rotas, fit the car without Flares? I am looking to get a set of wheels that fit without flares. If they do fit what size and dimensions are they? Do they bolt right on, no adapter needed?
  7. So i just took off the water pump and there is an area where the blades from the water pump scratched the housing, also there is little pieces of metal in the bottom radiator hose.. should i flush the system with water before i put the refurbished radiator on, and if so, what is the best way to do this, should i run water through the system by shooting water into the top radiator hose? any help is appreciated! Thanks, Brian
  8. Thanks guys, Thinking about an aluminum radiator off of ebay, anyone used this company before? looking for feedback http://cgi.ebay.com/ebaymotors/ALL-ALUMINUM-3-ROW-RADIATOR-74-75-DATSUN-260z-CC110_W0QQitemZ200317203293QQcmdZViewItemQQptZMotors_Car_Truck_Parts_Accessories?hash=item2ea3d5f35d&_trksid=p4506.m20.l1116
  9. So i took out my 74 260z for a drive after finally installing a new starter, I got it started and it ran well, There was a groaning noise coming from the front, i said i was going to order a new water pump as soon as i got in for the day. I took it for one last drive about 15 miles when i started making some real loud screeching noises, then the pump went, on my drive way about 200 yards from the garage.... but the pump shattered and i took the radiator out and the guy at the shop said he would have to cut out about 10% of the radiator, but he said that the car should run fine... should i get a new radiator or use the old one with 10% less capacity?
  10. where you from in pa? I live near scranton .
    Read more
  11. Interlagos blue is fantastic! rick i called the website the car was hosted on and I was told it was a custom color from japan..... that is a great blue as well, I was ready to paint it that color as soon as i saw the car... too bad..
  12. blueovalz, how did your experiment/ application to your car go? I am curious about doing the front of my car with 3m protective film right after it is painted.
  13. Thanks! the colors look great this is going to be a tough one. Here are a few good pics of the colors I initially listed: 1. Porsche Lapis Blue 2. Honda Belize Blue 3. Porsche Marine Blue
  14. KenshinX do you know what color that is for Curtis240z? I am going with a PPG BC CC. I was originally going to go with a House of kolors Cobalt candy blue however I was told that it is hard to match the original paint if i needed to get a scratch or panel fixed. Here is another pic
