bornagain280
About bornagain280
  • Birthday 05/21/1983
  • Gender
    Male
  • Location
    ga
Contact Methods
  • Yahoo
    ku
Recent Profile Visitors
3674 profile views
bornagain280's Achievements
Newbie
0
  1. Hey guys and gals, I'm looking for a R 200 pinion flange with the 2" pilot, that has a diagonal bolt pattern or 2.94 center to center and uses 10mm bolts. I have a 2.25 with a 2.75" diagonal center to center and uses 8mm bolts. Maybe a trade, if not, I will buy yours without trade. Any help would be great. Thanks, Chase.
  2. I know you're asking about a timing chain set, but I have heard that the ITM pistons are descent from Tony d. I'm probably going to end up using their pistons and timing chain set in my build. I don't have hands on experience with their parts yet, but I talked to zcar source about their "master engine kits" and they said that ITM is sometimes what they sell. He couldn't tell me 100% that's what I'd get, but said they did use them and ITM parts will probably be in the kit.... Pistons in particular was my inquiry . Sorry if this is not a direct answer, but from what I'm gathering they're not top of the line, but descent, and if properly set up, shouldn't be issue of failure. Maybe I'm wrong, but I'm looking at their parts too.
  3. EFI and ECU that is, for sale. I'll get you some pics if you're interested in it.
  4. We just pulled a l28 out of my buddies 280z. The previous owner labeled almost every wire on it and did a very good job with it. Complete with ECU. He told me that he wants to sell the motor or part it out.... let me know if youre interested. thanks Chase
  5. Okay, I guess its time to do a little reading, research, and math with this equation. I'm going to look around some more on Jeff p and his s130 too, maybe I'm searching the wrong keywords or member searches ? Don't worry, I'm going to do the math work and figure what will work best with my variables, then I'll know what it takes. Not just copying someone else. Thanks for all the information and knowledge from everyone and you tony d. I'm sure to need it again, and corky bells book too. Chase.
  6. I've rode 2 stroke dirt bikes for multiple years now and like turbo charging or any high performance engine I guess for that matter, you look out for detonation. I collapsed a ring land on a piston once in a rm 250, and all that I can figure is I mixed 87 with my race fuel instead of 93. Dropping my octane too low and causing detonation.... It was my fault, I got to runnin my mouth with someone at the gas station and grabbed the wrong pump. Luckily I did hear the engine pinging(easy when you're basicly riding it) and pulled it off the track, and saved the engine from blowing up. Never had any other pistons do that, so it had to be the fuel mixture, and that was a forged wiseco piston at that. I can understand the "detonating and not hearing it", with a loud exhaust and not much sound deadening in a s30. Very good information though, and I will do a full run and analysis at 8 psi when I go to tune this machine. I definitely don't want to toast any parts weather its a head gasket or piston. Learn to walk before I run so to speak. I think I also read another post that you mentioned coolant-temp detonation in regards to the size of aftercoolers blocking the radiators too much. Or at least higher coolant temperatures due to less airflow as a result of too large of a cooler. I'm not ready to buy a after cooler yet, but was researching optimal sizing. What is the most important variable when selecting one? I'm sure size has some to do with it, but potential flow due to inlet and outlet locations as well and overall construction design? I had a l28et built by sunbelt and I ran the largest spearco aftercooler I could cramp up front and looking back now, it was probably unnecessary and may have even been a issue. I never fully finished that car though to see its full potential. Im not in a race to build this engine, but pacing myself to make sure its sound and done right the first time and want to have fun and learn more while I do it. knowledge is power! As corny as it sounds. I
  7. I think you guys are solidifying my decision to run a standard head gasket over a mls, and keep some coin in my pocket. I definitely plan on taking the car to a dyno after I get it running and tune it before I take it out and have fun with it. The shop Im looking at agreed, the pistons are the next breakable part if the head gasket is blow proof, but did agree the stock pistons are pretty tough. He said he could help me get a few parts that I'm looking for, but I'm going to be careful, as I'm sure, I can source some of these parts myself. The whole 89 mm head gasket size is more clear too, since z ya mentioned extra spacing allowing one to unshroud the valves, which I was looking at doing, but waiting till I got my actual head gasket I'd be running, so an exact mark could be made. The soot mark is very defined where the factory head gasket is larger that the bore, but I'm not going to trust that when I start removing material. I've also seen ITM pistons around for sale, its just convenient to get most of the parts in one kit.....I wonder what manufacture supplies the pistons in the Z car source master kit. Don't need any Chinese crap, a lot of that Chinese imitation stuff out there now . I'm going to look around some more at the ITM pistons and see about piecing the rest together and see how I feel about it. I've gotta say too....475 on a stock bottom end has made me feel a lot better about the cast pistons too....sometimes reassurance from someone that has done it before helps. I would love to see his build specs on his engine. I know, I know, "search functions" ...lol. Kidding. Thank you guys a lot on this info., it makes me a lot more confidant that I'm going the right direction and don't need to throw thousands at a engine to get good results when proper built and tuned. Chase.
  8. This is the information I was wanting to figure out, and opinions are always good! I wasn't too crazy about $250-$400 HGs, and a lot of the MLS ones were 89mm that I saw and would require more machine work=more cash. I'm not building on a shoe string budget, but being cost effective and doing it right the first time. I don't see overboring to a 89mm really boosting my power numbers significantly in the money to additional power ratio, as long as an efficient turbo/aftercooler/engine management is used. Maybe I'm wrong? I follow what you're saying too Timz, there are guys that I work with that look at me crazy when rechecking torques after completing the initial torque sequence, and a lot of the time the first several in the sequence do require a little more torque after completion. Also when building and beefing up crane parts at work, I sometimes have to remind the higher ups that once one part is strengthened, the part next to it now becomes the weak link. So the cast pistons will be a variable in the equation, and is why I'll be happy with a good streetable 300-350 hp. I fully understand detonation is not a friend and want the fuel to "burn", not "explode". One of the reasons I did pick up a sds and plan on taking it to a local shop for dyno tuning. It has maps in it already, that made around 400 hp, 400 tq on another l28et that I bought from nelsonian here. I'm pretty sure that's a bit more than what my build would tolerate, so I need to be careful and most likely remap. I talked with zcar source, and the HG in this kit is a OEM comparable....so nothing special. I don't think I'm going to require a bullet proof $400 top of the line HG, but wanted to see what the next step up from stock would be. Another guy I know local recommended "cometic" also. Might be an option and Ill continue shopping around. Any more opinions are welcome, and experiences with particular brands....I guess a good question now is, are there any benefits to a MLS HG when running cast pistons? Would the head gasket supplied with the z car source master kit be acceptable when tuned correctly and achieve 350 hp?? Which is pretty much comparable to a stock composite. Chase
  9. I was looking at buying a master rebuild kit (pn 15403008) through zcar source. Kit looks like an overall complete kit, which I like, and also available in a standard bore (as long as my block checks out), or as close to it, without overboring. I know I'll be limited by the cast pistons, but I'm being mindful of my wallet. Im looking for 300-350 hp, I'm going to call zcar source and get some information from the particulars of this kit first hand(closed today), and see how far I can take the head gasket in their kit. I haven't had much luck finding a standard bore "mls" headgasket, which seems to be the best option, I'm trying to keep machining cost down by not punching the bore out, and not let the monster grow too big and put money in other areas. SDS, turbo, after-cooler So, guess I'm asking for head gasket options, opinions on durability, or sources that are as close to standard bore , but are mls gaskets. I'm wanting to buy the right part the first time.... thanks Chase.
  10. bornagain280
    back again
    found a nice 76' , making this my 4th zcar. Gonna hang onto this one, took a bit to find one this solid. No engine in her, lookin for a l28et to throw at it.... have a l24, but don't think thatll do justice.
  11. Yeah i figured I might be crossing a line possibly.....sorry for that. Thanks for the opinion on pricing it out, and I'll prob do just what you said and see where it goes. Ran into some guys I knew and found out they're into zcars too, so theres another source. Need to make room in the garage...lol. thanks again Chase
  12. I was unable to post in the classified ads due to being a newb.... been some years and guess my old sn and email got recycled so starting anew. I have a pretty much stock L24 that im gonna let go. Goin with a l28et . I recieved the motor from another friend that did a turbo swap as well and he didnt need it. Said it was rebuilt with only a few thousand miles on it. P30 block, E88 heads, N36 intakes, stock cam, 280zx dizzy, 3-2-1 header, 4 screw round top SUs.....just curious what a good price is to ask on one of these nowadays? Might be a good candidate fot zcar.com, for more purist ? Cool to be back in another Z, hope im not breaking forum rules. thanks Chase
