xringx
Location
Ohio
xringx's Achievements
0
Hello, Here is a pic of the current setup. The setup is cut springs with Yoko 205/60R15 on Panasport rims I am going to be putting on in a few weeks the Stagg shocks and spring stuff. I know its going to raise the height of my car and the distance from my tire to fender. If I dont like this setup I will give it a season or 2 and then go coilovers. But for the price, hard to pass up as a get by thing. I just got a flat and really all the tires need to be replaced. Since I know I will gaining some height from the spring change, should I take advantage of that and go with 205/65r15 tires? Cut down on the gap some and add a bit of extra cushion from a taller tire. Or am I missing something. This isnt my best subject and I have little experiance And any thoughts on tires? Thanks
Looking to buy L24, L26 or l28 with carbs to swap in to 78 810 wagon
xringx replied to boundish's topic in Parts Wanted
Hello, I have a L26 with 4 speed tranny and SU carbs.. all original. Engine ran well, trans was very rough. Also have a LS1 with Hawkes straight headers, motor mounts and a T56 with a conversion kit if you want.....a bit more than your 1000 though.... -
https://dayton.craigslist.org/cto/5241877819.html its in ohio...LS1 and T56 with headers per listing are available..
Budget is 25k ish... To pay in my top end of budget, the car will have to be completely redone with an LS engine in. Also willing to look at cars that partially complete. Maybe something like redone interior and exterior, but engine/suspension is original or the etc. Obviously not top of the budget. Thanks
'74 260Z front frame rails are TOAST...need sage advise...
xringx replied to xringx's topic in Fabrication / Welding
Also.. really appreciate the names of those that have gone before me on this... I have trouble searching on here for some reason... -
Rest of car is good to very good.. very minor outer damage to the body (spot on the hood).. no rust damage in the back end. There are some pinholes where the front windshield gasket was and water would be trapped..but other than that.. its all very good. Floor pans need replaced and firewall needs repairs. -
Pics say it all....rusted, spongy crappy crap Drivers side 1st Passenger side 2nd.. I really dont want to scrap the car, as you are seeing the worst. I am a fair welder with an excellent shop and tools. Here is what I am thinking: 2.5" square tubing all around. Mary up some Badog floor pain rails? I have never done this on a car. Is this thought process correct? 1. level car, measuring level on the door frame sills. 2. cut out front frame at the bend on the top where its spot welded to body work (need repair there also) 3. cut out rest of rusted sheet metal parts 4. repair sheet metal in prep for new frame rails 5. level new frame rails, weld in
Listing says.... "Viscous limited slip differential. This is pulled from a 91 Nissan super hicas 240sx se, 6 bolt half shafts. We installed it in a 95 240sx so it currently has the backing plate for the S14 body. Also has the ABS sensor." This is going into my 74 260z with a LS1 engine and a T56 transmission..
Eric, I sent you a private message about the engine...
- 30 replies
- 260
- Restoration
(and 2 more)
Tagged with:
Yes, its quite ugly, and since I posted it has become uglier...I thought I could patch the floor pans, but a total replacement is needed. Soooo.. As for MIG.. I dont have a mig unit at home.. just a tig/stick rig... I still have to pull the engine and stuff...but once that is done I will start cutting and see where we end up....
Eric Z.. I am pulling my working engine from my 1974 260z today of maybe this week. I will be selling it. Let me know if you have an interest in it. I will also be replacing my electrical.
- 30 replies
- 260
- Restoration
(and 2 more)
Tagged with:
LS1Gen3 and stock suspension part and the etc....
xringx replied to xringx's topic in Gen III & IV Chevy V8Z Tech Board
My bad.. I just checked my paperwork.. I have a T-56 This is what I have... 98-02 Camaro/Firebird LS1 Tremec T56 6 Speed Manual Conversion Kit Complete Used. Are you looking into converting your automatic f-body to a manual 6 speed? Then this is the kit you need, comes complete minus a console shifter plate (*SEE PICTURES*). If you have any questions feel free to ask. Comes with everything you need including: Tremec LS1 T56 6 Speed Transmission 2.66 low gear Bellhousing Slave & throwout bearing Crossmember Shifter, Knob, & Lower Boot Clutch master cylinder Manual pedals Clutch Disc, Pressure Plate, & Flywheel Bolts, Pigtails & hardware -
Thanks a million guys!.. I will do the compression test before I list..and will toss in the tranny for "free"..... If I get 500, I would have recovered half of the cost of the car!...LoL
