Jboogsthethug
Everything posted by Jboogsthethug
  1. This week I went the distance and cut my fenders. It was pretty terrifying to think about but once I started I realized as long as I didn't royally screw up I'd be ok as it would all be covered by my flares. I did my best to get them perfectly asymetrical when I placed the lares on and drew the outer lines. I used those outer lines as guides and with a measuring tape marked an inch inward all the way around (although I have seen other people use a half inch to 3/4in, my flares have a wider edge so I opted for an inch for extra room to bend them up), then on the edges went straight down with the cut as best I could. My best go at making a upside down U. Now on to the welding and pounding of the rear fenders!
  2. Hey Dennis, Good to know, I haven't found any repro's yet. one of the stems broke off at the base and got lodged in the hose, I hoped to get it out and possibly repair it but in getting it out the stem was damaged beyond repair so I am looking for a replacement. Know of any that match up? Even one that isn't original but has the same amount of inlets will work for me.
  3. It's been a bit since I posted, here are a few updates. I've been focusing a bunch on the flooring, chiseling out all of the old sound proofing. I'm trying to get it all out of there so I can check the condition of the metal underneath. Sadly, I've found a few spots on the passenger side where it's rusted through, but luckily the driver's side is perfect! also, it seems somebody tried to jack the car up from the middle of the passenger side and bent the floorboards up and part of the trans tunnel out, dummies. oh well, I'll fix that too. had to get a few screws out with some clamps but no worries. As you can see, it cleans up nicely! you can compare the two sides pretty easily, I will probably cut out those spots and weld new metal in the specific spots rather than do a full new floorpan. I can't find any place where they sell single sides, I can only find sets. anybody know of a place? as you can see I pulled the dash out. I have a chevelle that I am working on as well and I made the mistake of not marking each wire, not this time though! It took a few hours because of how meticulous I was being but it will be worth it putting it back in. I also finally got around to putting my rear flares on, I still haven't done the cutting but I figured I'd bolt it all on and check it out before doing any cutting. screw holes are easier to fix than a whole sheet. hoping to get the fronts on later today, wish me luck. j
