Jboogsthethug
Everything posted by Jboogsthethug
  1. I can't wait to see this continue! 300 dollars is dirt cheap for what you got, sure it needed work but every z needs work. stoked to see another utah z!
  2. I got around to doing a few things today with my sexy babe today, aka my z! so first of all, I am terrible at welding. Don't judge the welds, I am slowly getting better and this definitely has been good practice for me. but some of them turned out good after grinding so I am happy! This is what my welds to fill the trim holes ended up looking like: not bad at all considering previous weld jobs I've done. I also began pounding the inner fender of my rear fenders and Tack welding those. Mind you, my tack welds look like I was trying to weld, whereas I was actually just trying to get a good tack. This is what the pounding looked like. I'm trying to get the inner fender to touch the outer fender. once it got close I started on the next part. the next part being the tack welds. as you can see, my initial welds I had to grind out, that was also right handed. I decided to try it left handed on the left and the welds came out a lot cleaner and stronger. weird. I also cut out some cancer and scooped out some of the original fender sealant that had fallen down. I'll do the same tomorrow on the other side and get some new sheets put back in. Also, big shout out to 88DangerDan on here, he saw my need for the resevoir tank as mine was broken and he sent one over to me after I sent him some money for the shipping. Very cool thing to do, thanks mate!! More tomorrow!
  3. So this week I've focused on getting the body ready for paint. First things first, I need to get those rear flares welded together. I started by ripping out the sealant, it turned out to be pretty easy. I was able to get inside the car and go behind the whee; wells and use my hammer and chisel to scrape both sides of the sealant and push it out through the gap in the fenders. I also did the same on the outside for the front sides of the flares, but after scraping them i pivoted the chisel to pry the pieces out be careful when doing this, I slipped and it cut my finger pretty dang good, but this whole process took me 15 minutes tops. after that, I grabbed a sheet of metal from my local store, picked up glavanized without thinking about it, my bad. for those of you not familiar if you weld this and breathe in the fumes it will make you super sick. so I went back for some cold steel, ended up cutting the crap out of myself with that sheet, took out a chunk of my thumb but after I put the piece back in place then gauze padded that beast all is well. I went to work by wire wheeling all the spots I needed to weld, including the holes in the side for the door trim. My brother is a welder by trade and so I got him to do most of the welding done so far. here we are deleting the rear bumper indents with sheets we've cut out, trying to make it as flush as possible then finishing up the rest with filler. NOTE: we tried initially cutting that piece and pulling it out rather than welding a new sheet on to cover it, that didnt work as it is part of the main body and would leave a gap on the inside of the car, so an extra sheet was cut. I also cut out a few of these circles by cutting squares then rounding them to delete the door mirrors and the antenna. turned out pretty good, held it in place with some decent magnets so we could tack. Thats all for now, I will update more in a few days. really stoked on how it's going. hope to have the body work done and get it painted in the next month.
