First off, as said before, the problem is not there when the internals are cool, first after some hard runs.
AF VS Knock depends greatly on spark advance. Less spark and less fuel can give the same power.
Knock is simply that the "peak" of the detonation comes before TDC. A lean mixture burns faster, so you would need less spark. Add more fuel, and you can add more spark. If it gives more power has been discussed for ages. I think so though.
Anyways, hope you see my point. Theres no "the rich or lean for that engine". I cant pull any boost, but I can add fuel. AF goal table is added as an attatchment. As you can see, Im trying to get 11.5, Im just not there yet, cause Ive only had a few miles of tuning before this knock problem came to my attention. If you read the whole thread, youll understand more.
Also added is my spark table. You may review it, but again, thats probably not where the problems are though, cause then the knock would be instant, not only after emptying one or two gears, and even if it was after emptying some gears, and the IAT went sky high, it WOULD NOT be as extreme (it sounds like the pistons hit the ground!! Worst Ive ever heard!)
Edit:
As you can see from the AF table, the AFs are richening up more and more from 12-11.5 from 180 to 260KPA (~12-28 PSI). This should be good. IAT retard will be enabled if needed. Ill start looking at my problems today, and see where I end up.
