Happy holidays guys,
I’m in the final steps of finalizing the wiring and inter cooling piping for my car which I am very excited about. The reason I am writing is because i was wondering if anyone would help me out with a base map for my Haltech computer. My setup is as follows
440cc injector
yukon Individual coils
t3/t4 turbo
walbro pump
using original dizzy
Any help will be appreciated ..
have a great holiday guys
i saw on the forums that you might have the base map for a similar setup that i have. my setup is 440cc supra injector, t3/t4 turbo , yukon waste ignition coils, and im using a e11v2. any help will be appreciate it .
I'm looking for 240z front and read bumper for my 77 datsun 280z. My car is going to the paint shop and i would like to have the bumpers painted too. You can contact me via email maurizracing@yahoo.com thanks
about 2-3 months ago i bought front and rear fiberglass bumper for my 77 280z from oscar. when i receive the package it had the bubble wrap marks on the gel coat not a big deal! about 3 days ago i try to install them with the hardware provided (not the greatest hardware) but i tried for the pass 3 days to install them with no luck. the bumpers are too big and will need too much flexing. i contacted oscar and im working on the issue ,hopefully i can resolve the issue and get a new set or my money back .overall good costumer service ill keep you posted on the conclusion to the bumper crisis lol
Im lookib to buy out of someone rocker panels for. My 280zx if anyone have a zx that they could cut the rocker panels. Out im willin to payy email me maurizracing@yahoo.com
hey im restoring my 79 280zx and my rocker panel corner is rusted,i was lookin at black dragon but they dont sell the corner by itself...they sell the entire back fender...my question is were can i buy the rocker panel corner by itself or can i use the z rocker panel corner to use on my 280zx thanks
I have a f59 block with a p90 head and 1mm headgasket head is all stock and block too ..im gonna be running megasquirt and. The 440 injectors. Also have the p42 intake bored to 60mm throttle body ...what else do u need information. Wize
hi everyone,
to make a long story short my girlfriend bought me a turbo since she knew i wanted one.The description saids "its a Dual ball bearing Garrett T3/T4E, T04E 57 trim compressor with 2.75" inlet and 2" outlet. Stage III turbine wheel with T31 4 bolt. Uses ATP-OIL-021 oil inlet fitting. T3/4 drain flange. Coolant in/out required (14mm threads - same as GT series ball bearing). Great 475HP turbo"...now my question is this turbo good for my L28et setup or it just too weak....running mega squirt and 440cc injectors...thanks
i understand that i just want to kno what steps to do so far on my list is get a E88 head,spacers,longer valves ,and shave cam and SU's..what kinda HP i will get with this setup
what if i buy flattop pistons for the F54 block ..and the P90 heads is good ..how much should i shave it of 0.80? i need help i have money its just hard to come by ...i need a good game plan to go by
Hi guys my name is chris and i have a L28ET motor .no turbo or intake/exhaust manifold..the motor has P90 head...F54 block with dish pistons.due to my budget during this thought times. I'm thinking of installing triple Weber on the motor..here the problem I'm new to the triples so i know I'm going to need flat top pistons and a different cam but what about the P90 head.what modification i will have to do to it?...I'm looking for some guidance on this one any help will be appreciated...My HP goal is 150-200hp .once again thanks
Hey guys,I was wondering if anybody ever used xr2 injectors for a L28ET.I found some info on them on the web hope this helps.300cc (13.9 ohms - high impedance/saturated) - dark/navy blue top - (91-94) Mercury Capri XR2.
Will they work for my engine ma goal is 15 pounds of boost and around 300hp..thnaks chris
Wigenout-s30:Thanks for the advice on the turbo i will put my time on finding a T3 turbo.Also i'm gonna buy a Megasquirt system,can i use my MSD 6A with megasquirt wired to it.Thanks Chris
thanks guys ..its very cheap...and is close to my house..ima go for it and if i want more turbo in the future i just get a garret to4..also what management ecu do u guys recommend that its cheap and reliable ..thanks
hey guys im going to buy a l28et motor this weekend that needs a turbo...so i found a t28 turbo out of a rb20det in good condition in my area for cheap..do u guys think it will work find or i should keep lookin i wanna run 15 pounds of boost on the engine....will the t28 turbo hold boost good..thanks
