wax
Donating Members-
Everything posted by wax
I have been talking with the guy who owns this car as well. The guy who did alot of the engine work is actually may machiest that does the cylinder boring for my race engines i build ( jetski). They have seen my manifold and are more than happy with the job i have done to reach the power outputs i am looking to achieve.
Who is trying to get 278N/A ?. out of this manifold not me. Some one commented they thought i had between 170-190 cfm of flow so i took it in the middle and said that enough to make 278hp as per cfm / hp calculator. Read back on what i said i am going to do. When its all finshed i will bring it to a uniform finish with a catrdrige roll and then get it sand blasted to give it the rough finish. Sure its a lot of work when i could have just made a different manifold I am suprised to hear you say that when you could have just put an RB engine in your car and made a lot more power instead of chopping up those heads. But like you i am doing ii because i want to and i can. I thought you of all people would appreciate that I am starting to pick up on this web site there is a lot of negative people. Not just in here but all around hybridz
Ok well i held it over the engine to see what it would look liek and to make sure the clearance was going to be ok. Its going to aim beside the radiator just where i want it. On friday i will be picking up the extra alloy plate i need to finish it off
Oh yeah I wore the socks to keep every one happy
Well got the manifold all tacked up today and have to blend the old body in to the new plenum Then its a case of welding it all up and making a top and bottom plate and then manifold is finished On the bottom plate i will weld a thicker plate so i can put in the map sensor and vacum fittings
TURBO = The replacement for displacement
It would be better i am sure if it had a straighter shot However it would put the throttle body right out on the side towards the inner guard Its way better than it was and with boost behind it i think its going to be ok Thanks for the heads up
I just think it will flow into number 1 better. And it will look a damn site better as well All good fun doing stuff like this. Knowing me i will make it then scrap it and make some thing else
Ok having a look around i saw some other manifolds other people had made and i like the way they flowed them into the front cylinder. I could see a shortcoming on my first design So i changed it a bit today, I think it will look alot better and should flow alot more as well. Of course it needs to be welded up and its just held together with tape at the moment. Hopefully i will get it tacked together on wednesday and then will make the plates to over all other holes. Should be excellent when finshed The front where the throttle body was will be cut off once i have the pipes tacked in place and then i will make a plate to blend in the front
Ok thanks guys thats the info i want Seems i may have read it wrong
I was just working out the calculation off the cfm you posted . 170-190 cfm works out to be 278hp http://www.speedwaybids.com/calcs/powerfromcfm.html Grinding naked is not going to work for me.Cartdrige wheel to the testes is not a good look. If it turns out to be a restriction i will just make another manifold, im thinking about getting it flow tested just to see what it does flow. a friend of mine has a flow bench
Yeah I think thats going to be the go
Just a stronger block I have two l28,s and i just wondering what one to use
I have read that some of the f54 blocks ( the early ones were higher nickel and are the ones to have Does anyone know how to identify these blocks
Thanks Thats information i wanted I will be watching it with interest
Ha ha ha I grind in bare feet The alloy gets stuck in the hairs on my toes
Wow a massive answer there You assume I have no idea what I am talking about and im just sprouting words I have found on the internet. I’m glad you’re happy with your Mega squirt Please don’t suppose to know what my income is and if I can afford a decent ecu or not. The fact is you get better driveability with sequential and thats what i am after This was never meant to be a Geek off about injection i just wanted an answer to my question I guess the answer is not yet
the valve idea works well , thanks for that yeah sock are the go in the house at the moment its raining again if i average your estimation of 170-190 and use 180 then the manifold will flow 278 hp Im not sure if many l28s are getting that in N/A trim With boost it should get along just fine Im looking to make about 350 at the wheels so i think it will be enough As far as the head yeah i am just going to give it a mild cleanup to get rid of anything that impeds the flow Thanks for the heads up Oh and i used to be a car mechanice before i saw the light and went with the valveless engine hahaha Not sure what this cam thing is however i have been using it as a lever bar .Is this bad??
No i am not going to polish it I am just getting the casting marks out of it so i can get it resandblasted to give it that sand cast finish all over, i havent finished it yet , the welding will need cleaning up , until that time im not going to hard on the finish Yes i will be welding flat stock to the cast , done it heaps before works very well
What i am looking for is an ecu that has sequential cababilty All the high end ones have it now . sure its not the only factor but you can get better driveability with it than with out it. My decision will be based on more than one feature of course , but an ecu that doesnt do sequential is not in my future. If you just after peak numbers then there is no need to go for sequential But if you want a better idle , better fuel economy and traffic driveabilty then its for you Surely the fact that all manufactuers have gone to sequential as well as professional motorsport shows it has some merit Have a look at this link http://www.efi101.com/forum/viewtopic.php?t=3877&view=previous&sid=1eaf7e9e61336048be157f17d6df2b56
Ok well more work on the manifold today its ready to get welded up now Took the egr right out of it Also removed the centre rib out of the manifold and took all the casting marks of it
Thanks for your honesty, its the first step You were impling that sequential was not a major feature worth worrying about I was saying what is the feature that mega squirt has that would make me buy it over another ecu that has sequential. If i was driving around at 100% throttle all the time then i would save money and go for a batch fire , but the reality is no one actually does that
Yeah i am aware of that The low end midrange is what you pick up with sequential easily. No i am not going to do the one temp sensor per cylinder as its to hard and expensive( though i could just egt it ). Going for 6 wide band sensors would just kill me. I just want the driveablity and the economy that comes from sequential.
Its a nissan l28 the reason I want sequential is so in the mid range and lower i can actually fire at an open valve The helps econmy driveabilty and midrange torque If i already had a batch fire i wouldnt care but since i dont have anything i may as well go for the best The vehicle is a turbo so anything that makes the off boost better is a good thing
