I have an L28ET that was purchased in a hacked up turbo swap, so far I have found that pretty much everything electrical and half of everything else on this engine is from different years only some of which are compatable. (ex; had a '78 N/A ecu and harness, '78 distributor, '81 turbo or N/A oil pump drive shaft, what I BELIEVE is an '83 block and internals, 'upgraded' injectors that I have no idea what they are from, front brakes from a toyota 4x4, the list goes on and on)
Anyways... as I'm trying to figure everything out and get it running I'm starting to wonder what year the motor actually is. Is there a way to tell? I've had all the internals rebuilt professionally already since the cyl walls were scored pretty badly, i told them it was an '83 but does that even matter? I'm treating it as if it were an '83 and the ECU, harness, distributor... etc. that I'm putting on it are from an '83. As long as i pick a consistent year will it matter what year the block was originally? I've had all the internals rebuilt professionally already since the cyl walls were scored pretty badly.
Any input on this topic would be appreciated, I've been searching this and other forums for a long time and all I could find were lists of specific parts that were different on the individual years of the L28ET, I couldn't find any information on the motor itself.
