Posts posted by ritrebor
+1 for white lithium grease. That was what we used to use on the door hinges.
ritrebor
That's about all you could do as I believe it's the foam under the top layer of the dash that is hard and brittle and is starting to split. Just redid my dash and after about 10 times I got all the cracks out. They start out small and start to split wider. Not a lot you can do to stop that.
ritrebor
Added a B&M Megashifter.
This installation started to snowball as the linkage on the trans interfered with the headers.
In checking everything out I would have to reroute the exhaust to clear the trans linkage.
Since I was going to reroute the exhaust pipe maybe now would be a good time to change the motor mounts to fit the chassis better. The original mounts were home made ones that did not fit well. The headers interfered with the headers so the PO solution was to grind down the steering shaft. LOL. Also the exhaust would hit the rear trans mount as they did not allow enough clearance.
So on with the remodel.
Still looking.
ritrebor
Still looking.
ritrebor
Still looking.
ritrebor
Looks nice. I will be doing mine soon. Looking foward to more pics.
ritrebor
Just follow the advise given here and buy the book from JTR.
It will save you money in the long run.
ritrebor
Still looking. Autopower wanted list price for theirs. Ouch.
ritrebor
Thanks I will give them a call tomorrow. Was looking for used since there is no wear and tear on them.
ritrebor
Still looking.
ritrebor
Rimal, those look nice. Can't wait to see it painted.
ritrebor
Still looking.
ritrebor
Looking for a Autopower Race Roll Bar for my 72-240Z. Located in Southern California.
ritrebor
Just did mine. I used a cheap 2" putty knife that had a blade that went all the way through the handle and a rubber mallot. The putty knife is great as it will bend and not puncture the floor metal.
ritrebor
Dash repair
in Interior
Posted
When I was fixing my dash I found that my foam was hard and brittle. Probably from years in the sun and age. The foam would split and start to separate and would start to split the outer vinyl covering. Short of replacing the foam I guess you could make the outer vinyl as soft and plyable as possible.
Here is a youtube video showing how they redo dashes.
ritrebor
