jtmny1999
Everything posted by jtmny1999
  1. Thanks But I found out theres a spacer for Automatic trannys that look like its part of the crankshaft well ama take it of this weekend and plug in the harness if eveything works i should be happy
  2. Igot Spark Back BECAuse I took the - Wire from the battery to the YW connector that goes to the ignitor is started for like a second but then it Died I guess my injectors and working because My fuel pump is Am really having A hard time so I thing ama go to the junk yard and get the dash harness and hook everything up together like the stock 280zx turbo Plus now I Cant even crank the motor I It did for a while with a new starter but yesturday it wouldnt grab anymore so I think I left the Spacer from the flex plate because it was auto before but am not sure. It shouln't be that far from the motor right ________ This is About how far it is from the motor housing were the flywheel starts.
  3. I did the conversion but it seems the flywheel I have is the wrong one because none of the starters I have work, the 79-82 or the 74-77 manual Do I need a different crankshaft or a turbo flywheel ?
  4. I Accidently Switched The the two plugs The one that goest to the distibutor its a black wire the other one is blue and it goes to this little cylinder looking think is that the ignitor?when I hooked the BW to positive and YW To - Battery teminals it sparked shorted something, so I switched it back the other way no more short but I Still Dont Have any Spark Could this have damage my computer? I then hooked it up the right way but i still have no spark Did I damage the coil or The Ignitor ? Any help Guys Thanks Alot.
  5. Plug 3 one more question LR fuel Pump Relay is that have to be hooked up if so + or - ? Thanks
  6. Thanks guys I will try to get it Started this weekend It should be faster than my 280zx turbo donor car Just wanna smoke my friends 350z but anyways if You guys have some pictures it will help me out alot.
  7. What to do with the ecu wire harness how do u make it work to start your car am stuck at this step with my conversion. can anyone help me out with this I really wanna start up my 240z turbo
