Sketch_hs
Everything posted by Sketch_hs
Venus Automotive in Sacramento, as stated a few posts up. Stock Toyota mounts, but one of them is from an aristo 2jz or something. I shaved a little off them, used the stock z isolators and built brackets off the subframe on the turbo side and and off the frame rail on the intake side, going around the steering shaft. Not totally happy with the intake sides mount, i might reinforce it some more. The steering shaft is right in the way. The transmission mount is 100% fab My goal is to make it a running/driving project car as soon as possible. I'll be cleaning up the wiring in the bay, and redoing all the charge piping later probably. Then eventually dumping the stock twins for a small single turbo and running engine management like mega squirt or a MAP2 ecu etc.
UPDATE: So I've been putting in about an hour or two on the car after work and spent my entire day off on it today. Cooling system is done except for a single heater hose Drive shaft done Charge pipes hooked up (will refine the set up later) Fuel pump in and working (Walbro 255) Fuel lines routed Clutch line done Custom V belt done for no AC or PS pumps (40 inches, thanks Napa!) Charging system wired up Start up video. This is the second start, but it started right up on the first try. Still need to do a lot of wiring, figure out one heater hose, make an exhaust, fill trans fluid, bleed clutch, test cooling system and complete throttle cable before I can drive it. I'll definitely be driving it this weekend though. Pretty excited!
PROGRESS! Spent 90% of my weekend in the garage. Mounts done, starting circuit done, power circuit done, and started mocking up charge pipes. nice! Close to the firewall Very close! Should have good weight distribution. Shifter lines up great. Still a lot of wiring to do. Sweet JDM shift knob that came with my swap.... I kinda dig it! Nice to be able to row through 5 gears on the Z Supra getting jealous from all the attention being given to the Z. That it for this weekend. I'll get some more work done next weekend and maybe some weeknights.
MEGA UPDATE! Sure is nice have a day off during the week. (I work four 10 hour days So this morning I did a brake upgrade on my customers V6 mr2 (1997 mr2 turbo JDM spec front brakes). Took about 2 hours he was very happy. Then I pulled the motor out of the Z! OMG easiest car to work on ever. Took about an hour to have it out Then I headed over to my local JDM parts imported and took a look at what he had. He didn't have any 2jzgte motors, but he had 2jzge and 1jzgte motors. I expected to go home motor-less but he offered me a deal I couldn't refuse. I got the complete swap with EVERYTHING I need for over $500 less that I expected to pay for JUST a 2jzgte engine. FREE DELIVERY! The owner of the engine importer lives 2 blocks from me! 1jzgte complete swap with r154 trans Drive shaft, worth over $100! Power steering reservoir (again worth a lot) - Yes this Z will get power steering eventually, and AC! A bunch of aluminum intercooler pipes and silicone couplers and even a ARC BOV! (worth like $200) And a cold air intake that came in it's toyota soarer clip AND the radiator fan shroud from the soarer which should fit my mkiv supra. I've been looking for a good condition shroud for awhile and the are hard to find and expensive. ALL of this for $500 LESS than I spend on my last engine only swap that took too months to arrive. PICS PICS PICS! Engine coming out: Pressure washed and primered engine bay. No more bare metal! Will probably paint factory orange in here... maybe. Don't really care. It's my daily! The guys over at Venus Automotive in Sacramento have everything you need, are friendly, will make you a deal no problem. They did the compression test right in front of me. HIGHLY recommended! That's the owner and forklift master getting my 1jz from it's proud top shelf storage Here the engine sits, waiting to turn the Z into a rocket ship. The Z looks a little concerned. The supra looks interested, but knows she's my TRUE love
UPDATE! The L28 currently in the Z has been SOLD! The best part of the deal is that I'll be installing it in the buyers Z, funding 90% of the engine swap! Engine will be coming out and going into his Z over the next two weeks, meanwhile it's time to buy a 2jzgte swap.
Made a new header back exhaust, I wasn't happy with the first one in terms of look, sound or fitment. Its a tiny bit louder that the last set up (has the rear can and an evo 9 resonator) Visually, I find it much more appealing.
If necessity is the mother of invention, then boredom was this weekends daddy. I picked up a someone ricey muffler can for $20 this weekend of craigs. Decided to slap it on the Z after a few beers. I made a 2.5 inch exhaust out of spare pipes from the factory header back. It sounds great, very quiet, I wish it was actually a bit louder. Personally, I know it's a big old can but I kinda like it, it looks better in person and quite aggressive Hate it, love it, it's probably coming off when I do the swap.
BTW, my L28 is for sale, complete good running engine and trans, located in elk grove, ca
OMG AN UPDATE: Well a small one. I found some time the other day to make some intercooler mounts and test fit it... looks pretty good and fits perfectly: Here is one of the things that's been distracting me lately... A NA build for a guys V6 Mr2! Ported heads and some other trick little bits. I also did order a rear sump oil pan for the engine swap on the Z. It's going to be a 2jz! Made up my mind....
Yes sir. Twin turbo 1jz that is
what? lol Picture from phone cam on Monday... looks nice after a weekend quick detail! Outside my shop:
1jz or 2jz
Still running great, daily driving. Check out what I found in the car today! Neat! Guess that answers the question of millage. 150k it is (wasn't sure if it was 50k or 150k, though i guess it could be 250k I don't think it is!)
Funny, I've got a MKIV and a orange z too! My supra is black though
Geez, those big rims look all wrong for the car. I would never go over 16"
I just swapped for rear disk on my 1975 280z I keep reading about some valve or restrictor for the drums that I should remove? Feels like it need more pressure going to the rear brakes if anything, fronts lock up easily (at least in the rain!) Anything else that should be done in the system? I'll be upgrading the fronts next Thank you!
Drove it around a bit (in the rain!) with the new brakes. Feels a lot different, stiffer pedal feel, braking power felt good and improved over drums once I got the rust and crud off the rotors by putting some heat into them I may need a brake bias controller in the near future. Next up will be a front brake (probably 4 piston) upgrade and getting the balance sorted out. I'm starting to realize just how much these old tires suck! They have horrible traction! It's amazing the car corners as well as it does with them. Oh well - have to burn them up first!
modern motorsport adapters! Finally got around to installing them today Just barely fits behind everyone favorite wheels! About 3-4 mm clearance! BTW here is a recent interior shot Forgot to upload this a while ago: And a preview of whats to come!
most recent:
Wow that's pretty wild. Looking forward to updates and moar pics.
Rear disk upgrade going on today pics later....
