Search the Community
Showing results for tags 'slave cylinder'.
  • Search By Tags
    • slave cylinder ×
  • Search By Author
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Found 2 results
  1. Car was running, went away to school came back and car still runs but no clutch pedal all of a sudden.... got under the car the slave cylinder moves when clutch is pressed. moves about 1/2" it looks like. open slave cylinder there was fluid. couldnt see any obvious leaks... where could issue be from...
  2. ******edit, one week later: seems the slave cylinders are all the same, even though the auto part stores have different photos for different years or car models.. i bought the "wrong" one, which had a larger outer diameter, and it worked perfectly. Hi! situation: I'm in a bind, I had to...
