Search the Community
Showing results for tags 'small block'.
Hello guys, what happened is that I put a new set of felpro performance head gaskets on my s c 350 and I found some antifreeze in the oil again. I removed the left side and it was very tight, however the right side came off very easy, they both were tightened to 70lbs. As the block is a good wrench and the heads are the edelbrock 6073 aluminum . This time I would like to replace the pistons rings, the pistons have marked 0.030 on them, are the rings the same size 0.030? Now if i tighten the heads studs on a cold engine and then repeat it on a warm engine could this prevent the heads from getting loose? I have arp studs and I don’t really know which ones I have. As they just have the arp letters Imprinted on the head. Should I replace them? Your help is appreciated.
- 3 replies
- 350 chevy
- small block
(and 1 more)
Tagged with:
My search for a good car ended up being pretty quick. I wanted a car that had a flawless interior, very little rust, but really did not worry too much about the condition of the engine or transmission because those are being upgraded soon. I lucked out and found a decent candidate, it was recently restored by an old navy guy but he wanted to let it go so he could fund a new corvette. It had very little rust, from what i could tell, the interior was in acceptable shape and the best part, It Ran! The only noticeable things wrong with it were some major dents in the frame rails from clueless mechanics jacking the car up over the last 30 years and a dull grinding noise when letting the clutch out which i am assuming is just the pilot bearing. I drove up to meet him the weekend after seeing the posting and ended up buying the car, this was late June of 2016, I was able to drive it the 250 miles home that day... kind of. My phone does not hold its battery very well and i was depending on the GPS to get me home, before i even made it to my state line, my phone died. This ordinarily would not have been a problem, but neither of the plugs in the car would work. I ended up stopping at a gas station to get a paper map and traveled like a caveman the rest of the way home. Then, the second i hit my county line, the clutch pedal just dropped to the floor and would not un-engage. I wrestled it into neutral and rolled into the nearest gas station. When i popped the hood i noticed the clutch reservoir was bone dry. Luckily they had some dot-3 for me to fill it back up and it lasted until i made it home. I would find the source of the issue later.
Hello, I have a question for anyone who is running the stock or stock like aluminum 3 core radiators with their SBC's. What radiator hoses are you using? I bought two of the "universal" hoses from o'reilly's and my total was over $50. Just wondering if anyone could pull the numbers of their hose so I can see if I can find a cheaper option. I haven't put the engine in the car yet, so there is still time to return the hoses if other options are available. Thanks, Han
