Search the Community
Showing results for tags 'su carb'.
  • Search By Tags
    • su carb ×
  • Search By Author
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Found 2 results
  1. Guys, Is there a way to tell if the carbs are worn out without some elaborate set up to tell if the shafts are leaking? I assume someone that knows what they're doing can sort of look at them, wiggle them some, and tell if they're going to work properly. I am mainly asking about shaft play. What...
  2. I have an L24 with SU carbs. I've had this idea of the ability to go from carbs to EFI and back relatively easily.This would require a bolt on replacement for the carbs. I'd still be using the stock intake runners and air cleaner. I'd also try to keep the TBs the same length as the carbs. This is wh...
