bobbyc Posted June 13, 2011 Share Posted June 13, 2011 i have a 97 4runner and the return line for the power steering is a bit mangled. i need to replace it...but the replacment piece is hard to find. it's the end that messed up, so i could easily cut it off...but that little hump holds the hose on. is there a way to recreate that bump so i don't have to replace the entire hard line? if i could i could just get a little longer rubber hose and reconnect. thanks Quote Link to comment Share on other sites More sharing options...
getoffmyinternet Posted June 13, 2011 Share Posted June 13, 2011 (edited) http://www.aircraft-tool.com/shop/detail.aspx?PRODUCT_ID=AP145 Edited June 13, 2011 by getoffmyinternet Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted June 13, 2011 Share Posted June 13, 2011 On 6/13/2011 at 2:32 AM, getoffmyinternet said: http://www.aircraft-tool.com/shop/detail.aspx?PRODUCT_ID=AP145 Link no workie.... Quote Link to comment Share on other sites More sharing options...
m4xwellmurd3r Posted June 13, 2011 Share Posted June 13, 2011 http://www.aircraft-tool.com/shop/detail.aspx?PRODUCT_ID=AP145 he had the wrong link attached to his text lol. just copy pasta what he already had Quote Link to comment Share on other sites More sharing options...
getoffmyinternet Posted June 13, 2011 Share Posted June 13, 2011 Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted June 13, 2011 Share Posted June 13, 2011 On 6/13/2011 at 4:20 AM, m4xwellmurd3r said: http://www.aircraft-...RODUCT_ID=AP145 he had the wrong link attached to his text lol. just copy pasta what he already had This is what I get clicking on OP's link.... "lol" http://www.aircraft-tool.com/shop/search_result.aspx This is what I get when your link is used... http://www.aircraft-tool.com/shop/detail.aspx?PRODUCT_ID=AP145 Quote Link to comment Share on other sites More sharing options...
m4xwellmurd3r Posted June 13, 2011 Share Posted June 13, 2011 Yeah, for whatever reason when he pasted the link here it created a link to a search result, but the text itself was the right link. expensive ish kit but I'd like to have it. I've had so many times when I wish I had such a tool. Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted June 13, 2011 Share Posted June 13, 2011 (edited) I know I saw a tool posted here (HBZ) that did the same thing, and alot less expensive. Just don't recall who/when posted it... Edit: I think it may be in a RB build thread. Edited June 13, 2011 by RB26powered74zcar possible location Quote Link to comment Share on other sites More sharing options...
motoman Posted June 13, 2011 Share Posted June 13, 2011 (edited) I think this is what your thinking of. http://www.theturboforums.com/smf/index.php?topic=140645.0 Here is another good one http://forums.turbobricks.com/showthread.php?t=58790 Edited June 13, 2011 by motoman Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted June 13, 2011 Share Posted June 13, 2011 Kinda, sorta... The one I remember seeing had a handle to roll the tube some how. Quote Link to comment Share on other sites More sharing options...
getoffmyinternet Posted June 13, 2011 Share Posted June 13, 2011 (edited) They sell them individually if you just need the one size. I'm sure there's a knockoff out there too If you're going to make your own a tubing cutter would be a better start. Edited June 13, 2011 by getoffmyinternet Quote Link to comment Share on other sites More sharing options...
Mike Mileski Posted June 15, 2011 Share Posted June 15, 2011 On 6/13/2011 at 2:14 AM, bobbyc said: i have a 97 4runner and the return line for the power steering is a bit mangled. i need to replace it...but the replacment piece is hard to find. it's the end that messed up, so i could easily cut it off...but that little hump holds the hose on. thanks It sounds like this is the low pressure return line and I bet if you just slide it on, use a correctly sized hose clamp, and tighten it good, you shouldn't have any problems. Mike Mileski Tucson, AZ Quote Link to comment Share on other sites More sharing options...
Nigel Posted June 15, 2011 Share Posted June 15, 2011 Unless he's using 3" intercooler pipes for his power steering line, I suspect your standard $15 tube flaring tool will do the job just fine. They'll typically flare lines up to 5/8"Myhttp://www.harborfreight.com/double-tube-flaring-tool-kit-66534.html link Nigel'73 240ZT Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted June 16, 2011 Share Posted June 16, 2011 On 6/13/2011 at 6:07 PM, RB26powered74zcar said: Kinda, sorta... The one I remember seeing had a handle to roll the tube some how. On 6/15/2011 at 9:48 PM, Nigel said: Unless he's using 3" intercooler pipes for his power steering line, I suspect your standard $15 tube flaring tool will do the job just fine. They'll typically flare lines up to 5/8"Myhttp://www.harborfreight.com/double-tube-flaring-tool-kit-66534.html link Nigel'73 240ZT LOL... you are correct. I was remembering a IC tubing thread with my remarks... Quote Link to comment Share on other sites More sharing options...
