datsunranger Posted July 7, 2011 Share Posted July 7, 2011 (edited) I had a question, does anyone have a complete wiring diagram for wiring a 6-wire 280z wiper motor and with the self park function. Im rewiring my entire car, all new wiring with megasquirt and im having trouble getting mine to work correctly. Of course it worked fine before i gutted the car, the only thing that i never had a problem with. I have pulled the fsm up and traced pretty much everything, wired everything to the intermittent module, i get int, low, hi, but dont understand what i have to do to get the wipers to park themself. Edited July 7, 2011 by datsunranger Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted July 7, 2011 Share Posted July 7, 2011 Something tells me the answer is in this post > http://forums.hybridz.org/index.php/topic/17385-improving-the-wiper-motor/ Quote Link to comment Share on other sites More sharing options...
deja Posted July 7, 2011 Share Posted July 7, 2011 (edited) Make sure you still have ground at the wiper switch. When I rewired mine that's what I left off, its jumpered over from the ignition switch side of the steering column harness. Wipers would move but would not park. Basically the green and yellow wire at the switch needs to go to ground when the wipers are turned off. Ignore the fuse 14 note in the schematic, that's for my fuse block. Edited July 7, 2011 by deja Quote Link to comment Share on other sites More sharing options...
datsunranger Posted July 7, 2011 Author Share Posted July 7, 2011 Most informative, i will try wiring it tonight after class and see how things work out, thanks Quote Link to comment Share on other sites More sharing options...
Terentellie Posted April 26, 2024 Share Posted April 26, 2024 On 7/7/2011 at 5:32 PM, RB26powered74zcar said: Something tells me the answer is in this post > http://forums.hybridz.org/index.php/topic/17385-improving-the-wiper-motor/ Something tells me, "No input file specified. " Thank you deja for posting the diagram. Quote Link to comment Share on other sites More sharing options...
