260/280 Dash
Z Greek
New guy here. I am building a 74 260. The dash is so bad in it, that I don't think a cap will fit very well. (I had this situation when fitting a dash cap to a badly cracked 68 Datsun roadster dash) I am looking for a good, or very good 260/280 dash.
I'm guessing the cap didn't fit well because of the raised area around the cracks. Use a carpet knife to cut around all the cracks including the raised portion. Bond the cap to the remaining plastic.
Do a search! There are other threads on how to restore a dash with little out of pocket expense but lots of elbow grease.
A good dash with no cracks is probably going to cost you more than you want to spend.
Edited by rossman
ZG-
You might also get more response if you post this in the "Interior" sub-forum. Or the "Parts Wanted" forum, if you're looking to buy something. If you're attempting to fit a dash cap, leave it out in the sun for a while before working on it....softens up the plastic a bit....makes it more flexible and (slightly) easier to work with.
Good luck with it.
r/John
ZG-
Good luck with it.
r/John
Thanks for the advice. Have a great weekend.
