Memphis280zxt Posted August 22, 2011 Share Posted August 22, 2011 I purchased my 82 280zx about a year ago and i am still finding random wiring issues with my car. Recently my dash lights went out along with my running lights, but my brake lights and turn signals work just fine. Im not very experienced with wiring repairs so I've been struggling to find the problem. Im 90% sure its a short behind the dash somewhere but i cant seem to find it. So my solution until i can buy a complete wiring harness for my car is to manually wire the running lights through a toggle switch i will install in the dash. So my question is how exactly can i run my own power wires to rig this switch to work? any help/references is appreciated. Quote Link to comment Share on other sites More sharing options...
GOTHALOSISM Posted September 10, 2011 Share Posted September 10, 2011 I too need to do the same thing. You can get power from the fuseblock to the toggle switch. Just make sure you get on that is swithced to 12v. Quote Link to comment Share on other sites More sharing options...
Miles Posted September 10, 2011 Share Posted September 10, 2011 (edited) I had a similar problem on my 240Z. It may not be a short. I traced the problem to a broken solder joint inside the light switch. Soldered the offending joint and had lights. I also keep spare light and turn signal switches on hand so I can just swap them in when diagnosing light problems. It only takes a few minutes to swap out the switches saving time having to go point to point with a volt meter. Did you check the fuses? Edited September 10, 2011 by Miles Quote Link to comment Share on other sites More sharing options...
