"rebuilt" engine burning oil
  On 10/10/2011 at 5:53 PM, stav2201 said:
It seems to be getting better,but if you let it idle for a while after running the engine very hard it starts to build up alot of smoke and then im back to where i started.
More info, after a couple days of driving the engine has been getting much better. Tonight I am gonna spray some seafoam into each cylinder to try and loosen up the oil rings. Unfortunately the car is running rich while boosting and something is wrong with the idle, every time i let off the gas and put it in neutral the rpms drop about 300. Also. if i am at high rpms and drop it into neutral the engine will sometimes die. I'm guessing a vacuum leak but i am not sure yet.
Edited by stav2201
